Micro SU-27 DIY ( 250mm )
Included are 2 scans .. Already done a test print , and they came out ok . Join the two sheets .. Cut out the parts . And then using (?) , I used 3mm Depron . For stuffing ! 10mm x20 Brushed motor One WL Toys F949 flight control board And a 1s Battery .. There is no one way of stuffing one of these .. How you glue it up and the stuffing is up to you . I have included a spot to aim for the CG . If you want to do rolls N stuff , then make sure you have Aileron .. Elevator might be a little touchy ( mine ) but the ailerons are SOFT ... Over all , a very easy Micro to fly . Just build it straight .. The fewer warps the better . If you go brushed , a hot little 8520 should do the job with power to spare . |
Thread Tools | |
Similar Threads | |||||
New Product | HKing Micro SU-27 w/6 Axis Gyro | Kruzr11803 | Micro Ready-to-Fly | 93 | Aug 19, 2020 04:56 PM |
Discussion | Byron 27% Sukhoi SU-26M Center of gravity ? | camarocab | Giant Scale Airplanes | 10 | Jul 29, 2019 02:05 PM |
Build Log | Foamboard SU-27 SU-35 Flanker Dual 55mm | carcynic | Scratchbuilt EDFs | 71 | Mar 15, 2018 10:48 AM |
Poll | Brushed SU-27 vs. Brushless SU-27, Both Art-Tech | R/C-Plane | Foamy EDFs | 12 | Dec 27, 2007 12:24 PM |
Help! | NESail SU 27 vs Ultarfly SU 27 | totalywicked | Pusher Prop Jet Models | 3 | Sep 01, 2006 11:16 PM |
