Jan 06, 2020, 10:01 AM
Loose wire on motor
Hi all,
Building a new Ez Fly foamie and I noticed a loose wire on the motor - see the photo. It is a HobbyKing hexTronik 24gram Brushless Outrunner 1300kv.The motor runs fine. Maybe it has been there all along and I just never noticed. Any idea what it is for? Maybe the start/finish of a winding wire?
Thanks!
Jim
Jan 06, 2020, 10:11 AM
Sokol
JureZ's Avatar
the heat shrink is covering the center of the star connection. There should be nothing else connected to this point.
you may see that the number of strands is equal to the sum of the number of strands that go to the three motor connections .
do not worry , all is OK.
Jan 06, 2020, 11:22 AM
Thanks!
Jan 06, 2020, 11:58 AM
homo ludens modellisticus
Ron van Sommeren's Avatar
What JureZ said in message #2.
The coils in a motor can either be configured in star/wye, as in your case, or configured in delta/triangle.
Configured in delta, Kv is factor √3 higher.
Nine coils, three per phase. Your Hextronik has twelve coils, four per phase, but you'll get the idea.
(text is not correct, delta draws factor 3√3=5.2 more current and power)
Jan 07, 2020, 12:07 PM
Thanks for the clarification, Ron. I have not studied at all how these brushless motors work.
Jan 09, 2020, 07:51 PM
vollrathd's Avatar
Here you go, I also have some information on how the software works on these ESC's. And, yes, it is very complex.
Brushless DC Motors & Control - How it Works (Part 1 of 2) (10 min 33 sec)
Brushless DC Motors & Control - How it Works (Part 2 of 2) (7 min 23 sec)
Discussion Rewinding stator questions on wire sizes, not a motor RAFster Electric Motor Design and Construction 4 Sep 27, 2017 02:22 AM
Question extra wires on motor Stanbur Electric Power Cars 8 Mar 16, 2017 07:41 AM
Discussion Motor very hot - plastic covering melted on wires ! Papabear26 Electric Plane Talk 16 Jun 18, 2016 06:37 AM
Discussion Which wires on ESC going to motor are positive/negative and signal wire? cannondale1974 Power Systems 11 May 15, 2011 09:57 AM
Discussion "Disgrace" must have been a loo-loo... arbilab Site Chat 28 Oct 10, 2010 12:07 AM
