This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Jan 13, 2020, 01:29 AM
Lithium Member
Herb's Avatar
More fuselage details ... basic Freewing pilots and cockpit. The intakes & ducting is done here pretty well ...
Jan 13, 2020, 01:32 AM
Lithium Member
Herb's Avatar
Standard Freewing y-connector blue box, cleans up the wiring nicely by using neat ribbon cables, and eliminating a rat's nest of y-connectors.
Jan 13, 2020, 01:35 AM
Lithium Member
Herb's Avatar
Fan installation detail, here an FMS 80mm inrunner fan with YEP 150A esc,
Jan 13, 2020, 03:37 PM
Lithium Member
Herb's Avatar
Rudder, elevator, aileron & flaps linkage installation, then after that testing all servos to make sure they work ...
T-33 servo testing (0 min 8 sec)
Jan 13, 2020, 03:39 PM
Lithium Member
Herb's Avatar
Gear doors, retracts & struts details for future reference ... The massive mains look the same as on the F-4 and L-39.
Freewing finally figured out that mechanical gear doors can work just as well are servo driven ones, with less buzzing and less bec load ...
Front wheel is ~45mm, rear ones ~65mm.
Note the ~5sec delay between flipping the retract switch and the gear going up.
T-33 landing gear operation (0 min 32 sec)
Jan 13, 2020, 03:46 PM
Lithium Member
Herb's Avatar
FMS 80mm inrunner motor fan and YEP 150A esc complete, only needed some slight foam dremel work. Some sanding on the intake fairing as well.
Outlet here is ~65mm, have still to measure the intake area.
Jan 13, 2020, 03:50 PM
Lithium Member
Herb's Avatar
Standard Freewing blue box installed, consolidates all the servos wiring with a clean ribbon cable. Instead of a rat's nest of y-connectors.
Note that the gear door sequencer chip is not used here, thanks to simple & effective mechanical gear doors.
Btw never had a single problem with any of these nifty blue boxes ...
As in the F-4 and F-22, one slot on the blue box can be used for the front landing light.
Jan 13, 2020, 03:53 PM
Lithium Member
Herb's Avatar
Marked the manual CG at 95mm, seems like a sensible conservative starting point ...
Jan 13, 2020, 03:55 PM
Lithium Member
Herb's Avatar
On it's feet ... size comparable to my Freewing 80mm L-39.
The higher aspect ratio wing is clearly visible, should make it slightly faster
Jan 13, 2020, 04:02 PM
Lithium Member
Herb's Avatar
She's a little big bigger (and quite a bit heavier) than my Kyosho T-33,
Jan 14, 2020, 12:37 PM
NewPil0t's Avatar
Great info here. Mine should be arriving today.
Jan 14, 2020, 11:09 PM
Lithium Member
Herb's Avatar
Had the maiden today late in the afternoon, plus four flights
The weather wasn't that great and only another lost soul showed up at the field ... All videos taken with my phone.
Only needed a couple of clicks of up, one mm down ele comp with flaps, my CG is now ~10mm behind the manual one.
Flies pretty much like a pattern plane (tracks even better than the L-39, which is hard to beat) and lands real slow ... Definitely a winner.
Now I can start the repaint, the decals should be here tomorrow ...
Maiden and five easy landings :
Lockheed T- 33 by Freewing 80mm EDF - Maiden and Five Easy Landings (3 min 47 sec)
Jan 15, 2020, 10:47 AM
2020 EDF Jet Jam
Robert Belluomini's Avatar
Herb, what packs are you using? Nice flight! Mine is ready, just need decent weather for the maiden.
Bob
Jan 15, 2020, 11:51 AM
Lithium Member
Herb's Avatar
Hi Bob, 4000mAh and 5000mAh Roaring Tops and HRB's ... She is slightly more agile on the 4000's , still 3 to 3.5 mins safe flying with throttle management.
Even 6000's would work, but what's the point
Decals should be here soon ...
New Product Freewing T-33 Shooting Star 80mm EDF Jet The Snake Foamy EDFs 775 Today 08:57 PM
Discussion Freewing Avanti S 80mm 9 Blade EDF vs 80mm 12 Blade EDF DUNCA Electric Ducted Fan Jet Talk 11 Jan 07, 2019 07:41 PM
New Product NEW Freewing F-14 twin 80mm EDF (Vendor-independent) SU-4ever Foamy EDFs 186 Feb 07, 2017 05:47 PM
Discussion Freewing 80mm Inrunner Version EDF - Motor Options? Alpha10 Electric Ducted Fan Jet Talk 19 Jan 25, 2017 05:41 PM
