Apr 10, 2020, 04:06 AM
Could anyone tell me how far apart the holes for the screws in the propellors are? Also the length of one prop?
Apr 21, 2020, 10:57 PM
Just got my 906 Pro.
Can anybody tell me how to use the sd card?
Inserted new 64gb sd u3 but nothing on it after recording vdo.
Movies and pictures are all on phone.
Formated sd card with pc, today trying again.
Any help and hints appreciated.
Apr 28, 2020, 06:53 PM
Could you measure the props for me please?
May 05, 2020, 10:04 AM
Everything RC
How can the 120m flight height be made higher? Is it a app limitation or a device limitation?
May 11, 2020, 10:53 AM
t00nz843z's Avatar
32GB max card size. 64GB will not be recognized by the reader.
May 11, 2020, 10:56 AM
t00nz843z's Avatar
ZLRC SG906 GPS Pro 2 Axis Gimbal FPV Camera Drone Flight Test Review
This long flying, long range drone includes a two axis stabilized gimbal for steady video from its HD camera. This is one of the better camera drones that I've seen at this price range.
Find it here.
and here is its flight demonstration.
ZLRC SG906 GPS Pro 2 Axis Gimbal FPV Camera Drone Flight Test Review (57 min 15 sec)
Pros
- Folding drone for portability.
- Brushless motors
- Takes 4K (4096 x 3072 pixel) photos, and 2K (2048 x 1090 pixel @ 25fps) video.
- Includes two axis stabilized gimbal. No fisheye, and with the inclusion of this gimbal, the video that this drone takes is reasonably good for a drone at this price.
- GPS and optical flow sensors for stable hover.
- Automatic return to home and landing capability on command, loss of signal, and low battery.
- 20 minute flight time.
- Over 600 meter control and FPV range.
- FPV video and advanced flight modes of circle position, follow me and waypoints are available using the Hfun Pro app available on Google Play here and App Store here .
Cons
- Although you can still record video and photos with out the app, use of the app for FPV and advanced flight modes requires a phone with 802.11ac WiFi capability. Not all phones have 802.11ac WiFi. To avoid disappointment and before purchasing, it is very important to first verify that your phone does indeed have 802.11ac WiFi.
- The HFun Pro app is very processor intensive. Requires a newer processor to operate properly. Older phones (like mine) may experience significant FPV video lag, and poor performance of some of the app's advanced flight modes (circle position, optical follow, and waypoints did not work with my phone).
May 11, 2020, 11:21 AM
t00nz843z's Avatar
14mm apart, and 90 mm from center of screw hole to tip.
May 12, 2020, 03:17 PM
I have same problem with my drone. I am tried 8GB transcent, 16 GB kingston and 64GB Samsung evo plus SD cards. The drone only create two empty folders: photo and video. No any video or photo on sd card.
Another people in local forum say that droid support SD with 64GB capacity. And they say that cannot work without phone connection.
I think that maybe HFunPro App bug, or firmware bug.
If you try open 192.168.100.1:4646 in browser you can see your firmware. My is response like : { "CMD": 0, "PARAM": { "FirmWare": "1.1.4", "platform": "A7-4K-3479-2-16-1-2-00100009-1-101-1-0-100-1-2-0", "pinp_X": 60, "pinp_Y": 6, "region": 32924, "cur_csi": 0 }, "RESULT": 0 }
May 12, 2020, 07:49 PM
t00nz843z's Avatar
Are you using the photo/video record button on the controller or via the app? When you press and hold the video record button on the controller, does the record light illuminate on the app, also showing record time?
May 13, 2020, 02:14 PM
It is not depend where i am use record button: in app or on controller. Buttons work independed: if i press on controller nothing change in app, and if i press in app that nothing change on controller. If all buttons pressed no video in sd card too.
May 13, 2020, 02:31 PM
t00nz843z, where are you use button for record video to sd card?
May 13, 2020, 06:40 PM
t00nz843z's Avatar
Advance above video to 11:47 to see it.
May 15, 2020, 03:18 PM
+1 on the problem with no recordings to SD card, tried a few different cards <64GB. The above video is in accordance with instructions and tested, to no avail. The drone does manage to write folders...indicates some other trouble than the SD cards.
May 16, 2020, 03:13 AM
I´ve now tried the three different formatting options for SD cards:
exFAT: No folders written
NTFS: No folders written
FAT32: Folders written, but no videos or photos stored. ;-(
I´ve also tried some not very logical options in the app settings (like recording off), but no difference.
I guess it is a broken camera/memory card module, a pity since the rest of the drone seems fine. It records nicely to phone.
May 21, 2020, 09:53 AM
Hi... for all gents having the recording issue!
I am waiting the delivery of my SG906 Pro... 3 weeks?
About the SD recording, it seems there is an app that is a temporary solution: "GPS Drone v1.0.16", used by our friend JFR900 in Youtube this month ( give a glance, but french spoken). However he says it is not working with all drone fonctions, at least it makes recording Ok!
This proves the app "Hfun Pro" is faultry: let us hope a future version correcting this bug ( and more) will be released soon. In the meantime, you can download and try it. I hope it will work for you. Let me know your results!
New Product GPS 4K (2 Axis Gimbal) Drone CSX-X8 - F11 Pro /CSX-X7 (SG906) US$129 5Gdrone Mini Multirotor Drones 5 Jun 06, 2020 03:49 PM
New Product FQ777 F8 Monster 4K 2-Axis Gimbal Foldable GPS 5g Wifi Drone DG_Soarer Mini Multirotor Drones 2 Jan 17, 2020 11:25 AM
New Product Hubsan H117S Zino 4K GPS 5G WIFI FPV RC Drone With 3-Axis Gimbal White - Portable Ver scousethief Vendor Talk 2 Dec 17, 2019 01:29 AM
New Product FIMI X8 SE 5KM FPV With 3-axis Gimbal 4K Camera GPS 33mins Flight Time RC Drone Quadc scousethief Banggood.com 0 Dec 10, 2018 06:13 AM
New Product Hubsan H117S Zino GPS 5.8G 1KM FPV with 4K UHD Camera 3-Axis Gimbal RC Drone Quadcopt scousethief Banggood.com 0 Oct 08, 2018 06:26 AM
