Jan 02, 2020, 08:40 AM
Scale Blade 330s
Here is one of my projects I'm working on. It's a Bell Jet Ranger with a 3D printed fuselage.
Jan 02, 2020, 09:22 AM
Looking good. The fuselage is the one your friend 3d printed for you? Please keep posting pictures as you progress.
Jan 02, 2020, 10:37 AM
Yes that is one of them. I'll start on the airworf next that he 3D printed. I got the base white color done I'll probably start on the stripes tomorrow then it will be ready for clear coat.
Jan 02, 2020, 08:50 PM
Getting ready for the blue spikes. That a lot of masking off for the blue tape!
Jan 04, 2020, 06:21 PM
Slideways at warp speed.......
kiwi_craig's Avatar
How heavy is the shell ? And what did you print it with -ABS ? PLA ? Or ???
The finish sure looks good, did you use a hi fill primer and the sand it before top coat ?
Jan 05, 2020, 09:58 PM
PLA. It's really close to another scale 450 fuselage that a have (AS350). Several coats of hi fill primer primer and painting to smooth it out and a little bit of spot putty in a few spots. Once I get the windows figure it out I'm going to clear it all.
Jan 06, 2020, 12:22 AM
VE7FM
TheSteve's Avatar
Looks amazing, being it is PLA though don't leave it in a hot car or out in the sun.
Jan 06, 2020, 08:39 AM
For sure. I'm going to test hover the heli tonight and make sure everything works like it should after having it taken all apart before I put it in the fuselage. It's way easier to adjust any before it's in there lol
Jan 08, 2020, 07:33 PM
Bare-metal windows.
Jan 16, 2020, 09:13 PM
Clear coat finish and just about everything put together. Just for a test fit then I have to pull the blades back off so I can balance them. And I still have to glue the navigation light wires on the inside.
Jan 21, 2020, 11:43 PM
helivsFMX's Avatar
I’ll subscribe to this! If you do an air wolf I might just need to place an order!
Jan 22, 2020, 08:37 AM
Update. The 330s didn't have enough power to lift because the fuselage is too heavy so I'm going to build a Trex 450 with a bigger motor and 4 blade head to put in it to see if that will work.
Jan 22, 2020, 10:26 AM
What was the all-up weight (with battery)?
Jan 22, 2020, 11:26 AM
I'm not sure but it look like the fuselage was about a pound heavier then the fiberglass one but that was using a cheap food scale
Jan 23, 2020, 09:41 PM
I think its hilarious that the 330s wouldn't lift. Thats a bit extreme. Too bad, it looks nice and you worked so hard on it. Maybe try to keep it within 5 times the weight of a stock canopy, just a suggestion. Can you adjust the thickness the canopy is "printed" at much? The minimum thickness may still be too heavy. The smaller helis you can use cheap small digital scales to weigh things, I guess thats more of a problem with bigger helis.
On another note. Is there a way with the 330s to tell if flight mode is set up correctly? The manual says the FC led has a slow green flash when ready to fly but that doesn't tell me what flight mode it is in. I want to be sure my first flight is with self leveling flight mode. Some small helis the led changes color from green to blue to red when you change flight modes from normal to stunt1 to stunt2. I'm worried because initially I set it up based on the spektrum dx7,8 with gear 50/50 and reversed. Before flying it I changed it to the dx6g2 settings of gear 100/100 and normal-and changed channel input config to 5gear-fmode. And rebound it. So I think its good now but am not sure. I have a spektrum dx6 g3.
News Horizon Hobby Blade 330 S RTF Helicopter Jason Cole Electric Heli Talk 150 Today 02:31 PM
Discussion Blade 330s Mortimerex Micro Helis 12 Jan 06, 2020 02:38 PM
New Product New Blade 330 S (BLH5900 and BLH5950) Yeti1234 Electric Heli Talk 3 Oct 28, 2019 10:33 AM
Article Fliton's Extra Mini 330 Scale Aerobatic ARF Review j_z_123 Electric Plane Talk 8 Aug 06, 2007 06:13 PM
Question large scale Extra 330 nickelback Giant Scale Airplanes 1 Mar 04, 2004 09:19 PM
