Jan 21, 2020, 04:18 PM
The little outrunner motors need high timing 26 - 30 degrees. The Pursuit is one of the best handling boat around & with a Leopard 4074 - 2200kv on 4s should do around 50mph, that Leopard motor is a y wind & timing set to 10 - 15 degrees.
Jan 21, 2020, 05:14 PM
Thank you for the info on the leopard 4074. I have been searching the internet trying to find out if it was a D wind or a Y wind.
I just assumed in the end it must have been a D wind as it was fairly cheap ( from china ) around £50. I thought a Y wind would have cost a lot more.... So looks like i was wrong. I better set the timing back up.
Jan 21, 2020, 06:05 PM
The timing weather it be d or y wind makes no difference in price of motors.
Jan 21, 2020, 07:25 PM
Just Plane Nutts
AirDOGGe's Avatar
A much larger prop means the motor will be spinning slower (and working harder). Watch motor temps!
And prop torque roll could become an issue with a bigger screw on back, so watch for that too.
Jan 22, 2020, 07:12 AM
Ok thanks. After a full run with 2 x 2200mah 40c turnigy lipos in parallel i noticed the motor was quite warm but not what i would call hot.
I will run a single pack with the 38mm and check how hot it gets before i try running in parallel again. Will also bring it in before it hits the lipo cut off and check temps. The little 30amp esc was quite warm so hopefully the 90amp will cope better.....
Jan 22, 2020, 09:40 AM
Just Plane Nutts
AirDOGGe's Avatar
That's a 3S boat. "2 x 2200mah ... in parallel" is only 2S power.
Jan 22, 2020, 09:47 AM
Why? Didnt he use 2x 3s 2200 giving him a 3s 4400?
Jan 22, 2020, 02:09 PM
Sorry guys my mistake, i did mean 2 x 3s in parallel. So yes its running 3s 4400.
Just soldering it all up now.
Jan 22, 2020, 04:36 PM
Its all done and programed. Thanks Jan for the tip on the program card.
Ive set the timing to setting 7 (22.5) the max is setting 8 and that is (26.25)
Not sure if i should go to the max with the stock motor.... But to be honest it won't be long before i order the 3500kv for this boat. ( will have to remember to prop down when i do)
All thats left to do now is get it in the water. Thanks again guys for checking this thread. Your info is much appreciated.
Jan 23, 2020, 12:31 AM
Just Plane Nutts
AirDOGGe's Avatar
I see. I was thinking of when FARMER ran a pair of 2S packs in series for 4S power. It really scooted, but hard on the 3mm drive train.
4400mAh(!) That much extra weight can have a big performance degrade effect on a small boat.
Jan 23, 2020, 04:42 AM
The strange thing was, when i tried it last week the speed seemed faster if anything. I was really expecting the extra weight of another pack to slow it down. I will get the garmin in there and check between 1 pack and then 2 in parallel. It surely must be slower though like you say.
I bet it was quick on 4s but yeah 3mm flex not really up to it. I have upgraded the stock flex in my volantex atomic to a .130 octura cable. Only slightly bigger than stock but it seems to be enough to cope with 4s.
Jan 23, 2020, 04:48 AM
It propably seemed faster because it Made more spray
Jan 23, 2020, 04:55 AM
Haha, quite possibly yes....
Jan 25, 2020, 08:13 AM
Just wanted to ask a quick question about my pursuit to save starting another thread... Does this boat need the trim tabs? Only ive seen some pics of the carbon version without any.... Or is it best to leave them on but bend them up slightly? Could be why mine runs a bit wet. I have taken them off to bend them up a bit as mine were slightly pointing down.... Was thinking about trying it with them off or is this a bad idea?
Jan 25, 2020, 07:26 PM
Just Plane Nutts
AirDOGGe's Avatar
You might have better luck asking in a Pursuit-related thread: https://www.rcgroups.com/forums/show...uit-mono-setup
Discussion Joysway Rocket brushless mimik Racing Boats - Electric 160 Feb 23, 2020 11:02 AM
Question Aluminum strut for Barbwire XL/ Joysway Rocket RNM75 Racing Boats - Electric 26 Nov 23, 2019 04:06 PM
Build Log Top switch panel replacement project for Atomik/Joysway transmitters. AirDOGGe Racing Boats - Electric 13 Aug 04, 2017 10:18 PM
Cool Joysway Rocket Deep V Pelleflgare Racing Boats - Electric 2 Jul 19, 2016 01:16 AM
Question Atomik Whiplash 24 and Joysway Bullet KrazyKoots Racing Boats - Electric 3 Jul 22, 2013 10:31 AM
