Holybro Durandal Flight Controller
Holybro designed a new flight controller that utilizes the STM32H7 microcontroller series.
Durandal is a new flight controller utilizing the STM32H7 microcontroller series
Holybro designed a new flight controller that utilizes the STM32H7 microcontroller series. As increasing numbers of drone companies and developers need to run more powerful models and build on more embedded memory capabilities, Durandal is designed to offer more performance for development needs.
Holybro harnessed from their extensive autopilot building experience in the past years and implemented a new vibration absorption system into the mechanical design of the hardware as well as integrated an IMU heater for sensors temperature control. Durandal is pre-installed with PX4 and is also supported by other flight stacks such as Ardupilot.
Technical Specifications:
  • Main FMU Processor: STM32H743
  • 32 Bit Arm ® Cortex®-M7, 480MHz, 2MB memory, 1MB RAM
  • IO Processor: STM32F100
  • 32 Bit Arm ® Cortex®-M3, 24MHz, 8KB SRAM
  • On-board sensors
  • Accel/Gyro: ICM-20689
  • Accel/Gyro: BMI088
  • Mag: IST8310
  • Barometer: MS5611
  • GPS: ublox Neo-M8N GPS/GLONASS receiver; integrated magnetometer IST8310
  • Dimensions:80*45*20.5mm
  • Weight: 68.8g
Voltage Ratings:
  • Power module output: 4.9~5.5V
  • Max input voltage: 6V
  • Max current sensing: 120A
  • USB Power Input: 4.75~5.25V
  • Servo Rail Input: 0~36V
Check out the Holybro Durandal Flight Controller Here
News Holybro Kakute F4 AIO Flight Controller Jason Cole Multirotor Drone Electronics 824 Nov 23, 2019 05:11 AM
New Product Holybro Kakute AIO_v1.0 32-bit Flight Control + OSD + PDB nitbeat Multirotor Drone Electronics 28 Nov 11, 2017 03:37 AM
Discussion the HK/Holybro MultiWii 328P Flight Controller w/FTDI & DSM2 Port dutchcommando Multirotor Drone Electronics 682 Aug 14, 2015 09:18 PM
Discussion Repairing a HK Holybro 328P Flight Controller? djas3616 Multirotor Drone Electronics 7 Jun 10, 2013 01:11 AM
