Jumper MPM have lower accracy, It need frequency tune when binding process. And internal antenna please. |
Version with a B&W screen please. Some of us see a color LCD as nothing more than a waste of battery. I'd love something like this but with a 480x272 B&W LCD though.
I like the neutral colours of this Tx - I would have bought an X10S if they'd had a similar scheme available. |
Latest blog entry: Eachine QX65 FPV quad review
B&W screen? YES!Quote:
Not only does a B&W screen consume much less power, it is easily readable in direct sunlight with the backlight turned OFF. Color is just a gimmick (and don't even get me started on the subject of touchscreens!) |
It looks like an incremental upgrade - with all the increments exactly right. USB charging, better sliders, page up button, larger battery bay. What not to like...
HB mention a better external bay, not sure what that means but hopefully it's slightly deeper (an M-LINK module doesn't quite fit the T16). There's also a suggestion of better internals, it would be nice if that addresses the problems some have had with the ribbon cables. |
Already there, when you turn off backlight completely, there is only a tiny draw from the screen. Turning it completely off would make no practical difference
Buying this or the Jumper T16 PRO would be my first venture into OpenTX. My impression of OTX so far is I don't want to do any frequency calibrations that I read about here in RCGs. Maybe that only refers to FrSky, but I'm not sure. A Tx should be ready to go out-of-the-box.
My primary Tx is a Spektrum. I like not having to remove batteries IOT charge. The form of this Tx is similar to Futaba and others. I like the Spektrum form of not having a long antenna sticking up, just waiting to be broken off. Does this have dual antennas, i.e. a vertical one and a horizontal one in the handle? The side sliders on my DX18 are the best. They're in the ideal position with the right feel. The ones I see on these models remind me of the ones on the DX9 that get lots of complaints. If you're going to copy the sliders, get the ones on the DX18. Can models be backed up and saved to a SD card or a PC? I don't understand all the bickering about cloning and copying here. Isn't OTX supposed to be open for copying? Isn't that why it's called OPEN SOURCE? As far as the hardware, I'm sure there's a factory in China pumping out stock cases, gimbals, with only a stamp here and there with Logos and name brands being different. I see this is chip-based for DSMX. RadioMaster is using the old legacy CYRF6936 chip. But Spektrum and Lemon are using a new Software Defined Receiver or SDR Rxs. Shouldn't Txs also switch to that since the legacy chips won't be produced anymore? Don |
To me it seems that the possible travel of the rotary pots on both sides is quite limited/short, too short for an appropriate controlled moving.
the only change I don't like is the smaller lambo light 6p buttons. I would have liked it more if they went the other way and made them bigger. Trying to find them with goggles on is challenge for me as it is.
Thread Tools | |
Similar Threads | |||||
Discussion | Jumper T16 Owner's Thread - (2.4G 16CH OpenTX Multi-protocol Radio) | jokeane | Radios | 5506 | Dec 26, 2023 02:42 PM |
New Product | Jumper T16 2.4G 16CH OpenTX Multi-protocol Radio | rotorsupport | Radios | 12400 | Dec 17, 2023 04:41 PM |
Discussion | Jumper T16 PLUS Owner's Thread - (2.4G 16CH OpenTX Multi-protocol Radio) | cbedfellow | Radios | 12 | Mar 04, 2020 01:40 PM |
New Product | Jumper T16 2.4G 16CH Open Source Multi-protocol Radio Transmitter Compatible OpenTX | alex_nikiforov | Banggood.com | 1 | Mar 22, 2019 01:12 AM |
New Product | Jumper T12 OpenTX 16CH Radio Transmitter with JP4-in-1 Multi-protocol RF Module for F | scousethief | Banggood.com | 0 | Jul 31, 2018 06:18 AM |
