May 22, 2020, 10:11 PM
I’ll bet rm would laser engrave a new set for you.
May 22, 2020, 10:32 PM
Bob AZ's Avatar
Off Topic..deleted to be nice!
May 22, 2020, 10:34 PM
I looked at the carbon face plate and it will fit.
Same bolt pattern
Just get a Jumper carbon front . If you like that.
Originally Posted by Bob AZ
So is this a Frankenradio?
Bob
LOL I guess you could say that.
May 22, 2020, 10:41 PM
I put the Jumper knobs on it. They look better. It is a flat metal like the buttons.
They go good together.
I like it.
I have new Jumper hall gimbals in the box. I liked the gimbals so I think I will try them.
I have a pack of the gimbal harness too
This will fix my loose throttle
May 22, 2020, 10:54 PM
You can get rid of the checken feet. The jumper front button plate fits. Just need to remove the Jumper label without damaging it.
May 22, 2020, 11:11 PM
I fixed the throttle. I had to remove all the oil with alcohol they put on the slider . Now it has enough drag.
May 22, 2020, 11:27 PM
Here it is all done for now,
May 22, 2020, 11:40 PM
Stay Safe, Stay Healthy!
coreless's Avatar
Radiokenmaster the module pin is in the same exact position. who said they are totally different ?
I still might put jumper gimbals in it. I think they feel a little better. They are deeper in the radio too.More stiffer on the springs.
May 22, 2020, 11:45 PM
Yes I like it now. Everything fits nice. Scroll wheel works great. Just have too live with chicken feet.
Knobs are defiantly better looking.
I am a pincher and my last 2 fingers hold the case. The thick back was very bad for me.
My opinion the gimbals are way to high on the radio.
That is why I like the Pl18 so much. thin and gimbals are in the middle of the case.
A lot lower.
May 22, 2020, 11:56 PM
RM back module bay is a little deeper. But the pins are the same height.
Another thing. The chicken feet should be blue LED or something.
Not orange chicken feet color.
May 23, 2020, 12:11 AM
Another thing. The audio is not muted like others. You hear a his all the time if you put it up to your ear.
Wonder if the next firmware will fix that. Just mute it when not in use.
May 23, 2020, 01:01 AM
Bob AZ's Avatar
May 23, 2020, 01:21 AM
OpenTX core team
3djc's Avatar
No it won't and it is actually great that it does NOT require mute : mute introduces a 150ms delay between audio is requested and it can be played, bad bad thing. TX16S doesn't need that extra latency
New Product Jumper T16 2.4G 16CH OpenTX Multi-protocol Radio rotorsupport Radios 10612 Today 02:38 AM
Discussion Jumper T16 Owner's Thread - (2.4G 16CH OpenTX Multi-protocol Radio) jokeane Radios 4100 Yesterday 08:25 PM
Discussion Jumper T16 PLUS Owner's Thread - (2.4G 16CH OpenTX Multi-protocol Radio) cbedfellow Radios 12 Mar 04, 2020 01:40 PM
