This thread is privately moderated by GroundControlRC, who may elect to delete unwanted replies.
Dec 28, 2019, 09:50 AM
Video
Nano F22 Brushless Parkjet Project - Test Flight #2 CG Validation & Tuning ;-)
Here is a link to the Video:
https://www.youtube.com/watch?v=UdVc3-GtEFI
The MODs turned out to be a huge benefit ;-)
In this Flight I'm continuing to evaluate the CG, Dual-Rates and Expo.
Thank you all for your continued support and for using our Affiliate links as it helps us tremendously taking on Projects like this one.
#GroundControlRC #GlueAndFly #ScratchBuildPlanes #MaidenFlight #Nano #Parkjet #F22 #F-22
Stay tuned for some improvements and future Test Flights ;-)
Here is a link to the Motor Mount Template I created for this Motor:
http://groundcontrolrc.com/ftp/templ...otor_mount.pdf
Below are links to all the Components used in this Nano Parkjet as well as some additional Receivers:
Motor:
Happymodel EX1102 8500KV 9000KV 10000KV 13500KV 2-3S Brushless Motor Original for Mobula7 HD Sailfly-X Drone - 13500KV 1.5mm
https://www.banggood.com/Happymodel-...47791920140372
ESC:
DYS XSD7A 7A Blheli_S 1-2s FPV Racing Brushless ESC ***This is the one I used
https://www.getfpv.com/dys-xsd7a-7a-...hless-esc.html
1S 2S 7A Brushless ESC With Boost Module 5V/1A BEC for RC Airplane Spare Part RC Module - BEC2S
https://www.banggood.com/1S-2S-7A-Br...47791920140372
Props:
Happymodel Sailfly-X Spare Part 6 Pairs 65mm 2-Blade Propeller w/ 1.5mm Mounting Hole
Happymodel Mobula7 Part 40mm 1.0mm Hole 4-Blade Propeller 2 CW & 2 CCW for 0603 0703 0802 Motor - Black
10 Pairs Kingkong / LDARC 1935 48.26mm 1.5mm Mounting Hole 3-Blade Propellers for 90GT Drone - Clear Red
https://www.banggood.com/10-Pairs-Ki...47791920140372
2pcs 9046 46mm Propeller for 615 716 Coreless Motor Electric Hand Throw RC Airplane
https://www.banggood.com/2pcs-9046-4...47791920140372
Micro Receivers:
DSM2 / DSMX 2.4G 4CH Micro Low Voltage Receiver Built-in Brushed ESC
Flysky AFHDS Compatible 8CH Micro Receiver PPM Output With 1mm JST Socket For DIY
https://www.banggood.com/Mini-Flysky...47791920140372
FrSky RX4R 2.4G 4/16CH Telemetry Micro Receiver PWM SBUS Outputs
https://www.banggood.com/FrSky-RX4R-...47791920140372
See you in the Air!
Ground Control RC™ Glue & Fly™ Series Scratch-Build Planes
See Us On Youtube | Patreon | RCGroups
