FOXTECH GS03 Ground Control Station
GS03 ground station is a compact and convenient solution for UAV. It features a professional layout and functions. The GS03 ground station can realize functions like radio control, data transmission and video(optional) transmission, etc. And all these functions can be controlled separately.
GS03 Ground Station
The GS03 ground station is equipped with a 15.6-inch bright daylight monitor, which is used for checking onboard video. You also can set the contrast, brightness and other functions by the buttons on the ground station.
The GS03 ground station is also equipped with a 10-inch touching screen. The touching screen features a fast response due to the built-in computer the processor of which is i5. You can arrange waypoints, flying routes through the touching screen.
The GS03 ground station has an HDMI recorder which can record 1080P videos, the videos also could be transferred to your storage device by connecting a USB cable. Of course, it also supports a real-time 1080P HD video transmission.
The ground station also can be used to control our GAIA 160 Elite HYBRID drone, there is a three-stage switch to control the stop, idle and work mode of a generator. And there is also a joystick, through which you can control the gimbal on your drone.
The GS03 ground station is built in a 20000mah Lithium battery for 3 hours operation time. You also could link a charger from your car, so that you can use the ground station without any time limit.
Specifications:
  • Dimensions: 460x350x180mm
  • Operating temperature: -20C to +60C
  • Case features: Rugged plastic case, carry handle, the pressure purge valve
  • Battery type: Lipo Battery
  • Battery capacity:3s 20000mAh
  • Battery operation time: 3 hours
  • DC power output: 12V
  • Display: 15.6 inch monitor,10 inch touching screen.
  • Built-in 16-channel radio control, standard 8km data transmission range.
Highly Integrated Ground Station Foxtech GS03 Introduction (6 min 52 sec)
Learn More at Foxtech!
Head over to the website for more info...
Discussion Quanum V52 ground control station Review scunna FPV Talk 15 Sep 10, 2020 09:17 AM
Discussion Which of these two Ground Control Stations would you prefer? Rubyra Multirotor Drone Talk 8 Aug 15, 2019 10:36 PM
Build Log Just another ground control station mishkarogachev Commercial UAV/FPV 2 Oct 31, 2017 03:48 AM
Help! 1watt DTF UHF openlrs + Foxtech Rx Kill on ground station. jps1 FPV Equipment 16 Apr 21, 2014 03:17 PM
