This thread is privately moderated by GroundControlRC, who may elect to delete unwanted replies.
Dec 24, 2019, 09:55 AM
Video
Nano F22 Brushless Parkjet Project - Time for the Maiden Flight ;-)
Here is a link to the Video:
https://www.youtube.com/watch?v=Jc-fjQTEia0
I was very apprehensive about launching this Nano Parkjet, that only weighs 26.1 grams, in 3-4mph Wind but that's about as good as it gets here.
So, thowing caution to the Wind we will perform the Maiden Flight of this Nano Parkjet!
Thank you all for your continued support and for using our Affiliate links as it helps us tremendously taking on Projects like this one.
#GroundControlRC #GlueAndFly #ScratchBuildPlanes #MaidenFlight #Nano #Parkjet #F22
Stay tuned for some improvements and future Test Flights ;-)
Here is a link to the Motor Mount Template I created for this Motor:
http://groundcontrolrc.com/ftp/templ...otor_mount.pdf
Below are links to all the Components used in this Nano Parkjet as well as some additional Receivers:
Motor:
Happymodel EX1102 8500KV 9000KV 10000KV 13500KV 2-3S Brushless Motor Original for Mobula7 HD Sailfly-X Drone - 13500KV 1.5mm
https://www.banggood.com/Happymodel-...47791920140372
ESC:
DYS XSD7A 7A Blheli_S 1-2s FPV Racing Brushless ESC ***This is the one I used
https://www.getfpv.com/dys-xsd7a-7a-...hless-esc.html
1S 2S 7A Brushless ESC With Boost Module 5V/1A BEC for RC Airplane Spare Part RC Module - BEC2S
https://www.banggood.com/1S-2S-7A-Br...47791920140372
Props:
Happymodel Sailfly-X Spare Part 6 Pairs 65mm 2-Blade Propeller w/ 1.5mm Mounting Hole
Happymodel Mobula7 Part 40mm 1.0mm Hole 4-Blade Propeller 2 CW & 2 CCW for 0603 0703 0802 Motor - Black
10 Pairs Kingkong / LDARC 1935 48.26mm 1.5mm Mounting Hole 3-Blade Propellers for 90GT Drone - Clear Red
https://www.banggood.com/10-Pairs-Ki...47791920140372
2pcs 9046 46mm Propeller for 615 716 Coreless Motor Electric Hand Throw RC Airplane
https://www.banggood.com/2pcs-9046-4...47791920140372
Micro Receivers:
DSM2 / DSMX 2.4G 4CH Micro Low Voltage Receiver Built-in Brushed ESC
Flysky AFHDS Compatible 8CH Micro Receiver PPM Output With 1mm JST Socket For DIY
https://www.banggood.com/Mini-Flysky...47791920140372
FrSky RX4R 2.4G 4/16CH Telemetry Micro Receiver PWM SBUS Outputs
https://www.banggood.com/FrSky-RX4R-...47791920140372
See you in the Air!
Ground Control RC™ Glue & Fly™ Series Scratch-Build Planes
See Us On Youtube | Patreon | RCGroups
Discussion F22 EDF signal loss on maiden flight strykerf27q Crash Discussion 5 Mar 24, 2016 09:12 PM
Discussion Nano CPX Brushless: Just more power or also longer flight times? kirby_ Micro Helis 17 Jul 04, 2014 02:51 PM
