Dec 22, 2019, 07:21 PM
Great Planes Waco YMF-5 engine?
Will this airframe handle a Saito FG-33R3 ? Any building tips?
Tim
Dec 22, 2019, 11:13 PM
lost in the addiction of flyin
furballll's Avatar
I am putting one together now and the cowl os 7.3 inches. This motor is 7.9 inches. Would be great in it but will not fit in the cowl.
Dec 23, 2019, 06:54 AM
The FG-33R3 fits in the cowl but not the trim cowl. Rats!
Dec 24, 2019, 12:53 PM
I mounted a Magnum 1.60 twin and it fits inside the cowl. I think a Saito 170 Radial may fit?
Dec 24, 2019, 01:21 PM
furballll's Avatar
Could you trim the inner part to make it work? I think it would be awesome sounding power in it.
Dec 26, 2019, 05:26 PM
If I take the front of the trim cowl off. The cowl will have no attachment point.
Dec 26, 2019, 07:14 PM
How about A Saito FG-30 ? Weight?
Dec 26, 2019, 10:17 PM
furballll's Avatar
FG-30 is about 1500 grams and a dle-35ra is 1047grams. The four stroke would probably pull it around great but would be very heavy on the nose. Note a 35ra is about 100 grams less than a dle-30 the manual calls for. The power output of the Fg-30 is closer to a 25cc motor.
Dec 27, 2019, 07:46 PM
30cc is unnecessary power. I fly mine with a vvrc 20cc. It yanks and banks with the best of them. You also need to be aware of the gear mount formers in the fuse. They have too many lightening holes in them making them a bit weak. Mine broke after five flights. The landings were NOT hard bounces. I'd suggest sandwiching those two formers with 1/8" ply. Mine is still flying after that repair. Lots of fun.
Edwin
Dec 27, 2019, 11:12 PM
furballll's Avatar
Does the 20 cc vvrc motor fit in the cowl? I was looking at the 40cc twin.
Dec 28, 2019, 12:09 AM
Almost. I have two vvrc 40cc twins. Its 8-3/8" wide. The waco cowl is about 8" wide without the blisters.
Edwin
Dec 29, 2019, 11:54 AM
edwin1 thanks for the heads up on the gear. Going with the FG-30. Can I run a single battery for ignition an radio?
Dec 29, 2019, 12:58 PM
Yes, but strongly recommend the tech-aero ibec. I've got 6 and never had a failure. I've got around 20 rcexl and over 20 years had 2 failures. Not bad enough to stop using. Just have to watch out for that.
Edwin
Feb 10, 2020, 07:29 PM
Update
Found an engine that will fit inside the trim cowl. Saito FA-120R3. I will have to put glow ignition on it.
Feb 10, 2020, 07:57 PM
Update
Will it have enough power for "your" flying style?
Article Great Planes Waco YMF-5D Biplane ARF 72" with OS 95AX 2-Stroke Review kingsflyer Scale Fuel Planes 121 Mar 22, 2021 03:02 PM
Discussion Great Planes Waco YMF-5D Biplane ARF .91,72" Laserdude Giant Scale Airplanes 0 Jun 14, 2019 06:42 PM
Build Log Great Planes Classic Waco YMF-5 Electrified Staggerflyer Glow to Electric Conversions 251 Nov 19, 2017 08:55 AM
Discussion Great Planes Waco YMF-5D Biplane ARF Servo What? gregoryshocc Fuel Plane Talk 6 Jun 21, 2017 10:29 PM
Discussion Great Planes Waco YMF-5D Biplane ARF .91-1.20 jonnyspeed Glow to Electric Conversions 23 Apr 30, 2012 05:51 PM
