Jan 08, 2020, 02:52 AM
Klemen P's Avatar
Originally Posted by E-Challenged
To reverse a brushless motor, all you need to do is reverse two of the three wires that go from motor to speed control. Some brushless outrunner airplane motors (Cobra motors) are set up for bolt on propeller adapters on one end and plain shafts on the other end for collet or set screw prop adapters. It is wise to use a wattmeter to assure that motor is pulling less than max amps that it is rated for under load. You can increase number of cells to increase rpm if amp draw is well under max continuous amp rated number. Enclosing motor in an outboard type shroud, with no cooling air flow, may overheat motor with sustained full throttle running.
Jan 11, 2020, 03:04 PM
Klemen P's Avatar
Another action with my favorite home built boat
G -370 sport boat - (3 view camera) (6 min 40 sec)
Jan 14, 2020, 12:29 PM
Klemen P's Avatar
Now is on primer,only paint more and new bigger hood for Evinrude is done
Jan 15, 2020, 09:48 PM
Klemen P's Avatar
Now they are both boats scale : D: cool:
Jan 20, 2020, 07:11 AM
Klemen P's Avatar
With this boat I have more luck and fun like my hydrofoil
some action from 2 hours ago
My scratch built boat with scale outboard and custom made cover (4 min 56 sec)
Jan 20, 2020, 08:16 AM
Latitudes vs Attitudes
Bob Gaito's Avatar
Klemen-nice video.. that cowling looks great! There is nothing like a 1960s retro model outboard..Question: is that motor strictly air cooled-and if so, no problems?
Latest blog entry: Mark V Navy Seal SOC
Jan 20, 2020, 12:19 PM
Klemen P's Avatar
Yes the motor is air cooled and nothing problems for now
Build Log NSRI Boat with Dual Outboards, 1/10th Semi Scale, Free Build Melbran Scale Boats 43 Feb 08, 2017 08:26 AM
Discussion Scale Evinrude outboard mitchlandry Scale Boats 6 Jan 13, 2016 09:13 PM
