This thread is privately moderated by cmdl, who may elect to delete unwanted replies.
Dec 20, 2019, 05:14 PM
http://www.sgvhumane.org/
cmdl's Avatar
Mini-HowTo
Climate change - two simple steps
Source: https://archive.epa.gov/climatechang...sics/past.html
Step 1: Eyeballing (or use ruler) temperature change with respect to CO2 on the left two graphs (upper is CO2, lower is temperature). Total temp change (F) divided by Total CO2 change (ppm) = Rate of change of temp w.r.t. CO2.
Calculate the rate for the two left graphs (before industrialization) and the two right graphs (after industrialization).
Step 2: Compare the rates.
For the left graphs (before industrialization), I got rate of change = (-15 F to 5F) / (175ppm to 300ppm) = 20 F / 125 ppm = 0.16 F/ppm.
For the right graphs (after industrialization), I got rate of change = (-1 F to 1.5F) / (300ppm to 400ppm) = 2.5 F / 100 ppm = 0.025 F/ppm.
The rate of change of temperature w.r.t CO2 before industrialization is 0.16/0.025 = 6.4 times greater than after industrialization.
Dec 21, 2019, 07:28 PM
DJO
DJO
"Yo, that's a thermal"
DJO's Avatar
This is a problem related to climate sensitivity, and not simple rates of change.
CO2 is a climate forcing; the relationship between CO2 and radiative forcing is logarithmic. There is much debate about the exact value of sensitivity, but even the skeptics would disagree with your analysis.
When we talk about direct temperature changes in the climate, we use (degrees C) / (flux), where the units are C and W/m^2. CO2 levels will make the flux vary, both coming into the atmosphere, and what is being absorbed after emission off the Earth's surface. This will then effect the temperature of the troposphere.
There is a "middleman" between CO2 and temperature (radiative forcing). The CO2 levels themselves will alter the rate of change of temperature w.r.t. them.
https://scied.ucar.edu/climate-sensitivity-calculator
Dec 21, 2019, 07:35 PM
DJO
DJO
DJO's Avatar
The exact logarithmic formula is R = 5.35 * ln(C / C_0)
R = radiative forcing (flux) in W/m^2
C = CO2 concentration in ppm
C_0 = reference concetration, normally 280ppm (for before the industrial age).
With C = 380 ppm and C_0 = 280 ppm, R = 1.633
With C = 410 ppm and C_0 = 280 ppm, R = 2.040
With C = 600 ppm and C_0 = 280 ppm, R = 4.077
Dec 21, 2019, 07:37 PM
DJO
DJO
DJO's Avatar
More info if you are interested:
https://skepticalscience.com/C02-emi...re-growth.html
Help! One step forward two steps back Papasmurfy Beginner Multirotor Drones 6 Nov 19, 2017 08:43 PM
Discussion Trump softens stance on Paris climate pact..... and man induced climate change Sonny McGhee Life, The Universe, and Politics 111 Nov 24, 2016 04:54 PM
Discussion Next simple step up from kk2 board phil419mike Multirotor Drone Electronics 0 Nov 16, 2015 08:05 PM
Yippee! Is Climate Change Causing Climate Models to Fail? UlteriorModem Life, The Universe, and Politics 8 May 08, 2015 08:04 PM
Discussion Barbara Boxer: Climate change "leading cause of conflict" over the next two decades. craab Life, The Universe, and Politics 24 Jun 17, 2010 01:14 PM
