Jan 10, 2020, 05:52 AM
flyin' fool
goldguy's Avatar
How about the specs on the 18" Dave. Need a comparison.
Thanks: Frank
Jan 10, 2020, 10:28 AM
pull up -- PULL UP!!!
Since you moved the CG back would your 18 no longer need the nose extension?
And I'm sure this is obvious, but it's early still...U/C = ?
Jan 10, 2020, 11:19 AM
r/cdawg's Avatar
Nicely done Dave. The 18" looks to fly just like my version.
Jan 10, 2020, 11:33 AM
r/cdawg's Avatar
Originally Posted by hard line
....And I'm sure this is obvious, but it's early still...U/C = ?
Undercarriage or landing gear.
Jan 10, 2020, 12:01 PM
Oh, you mean LG. I think of U/C as undercamber and was picturing a potato chip wing. Which I think has been done on roundy's.
Jan 11, 2020, 01:21 AM
davereap's Avatar
Very likely..
But the extension was easy to add, and does not affect the flight..
Now without any lipo on board the model is balanced exactly at a 25% COG on the circle....
The lipo can be positioned on the COG, or moved back and forward to suit , basically any reasonable size can be used, I used a 450-500 2s
The U/C or L/G is a simple "X"made from CF rods lashed together with an axle and wheels
specs... 18 dia circle..racerstar 2304-1850.. 8x4.3 sf prop.. tgy1440a servos.. 12A ESC .. mini orange 4ch RX.. 7-8mm EPP..
weight with wheels 149g.... wing loading with a 450 2s =3.48ozsqft... sorry about the mixed numbers..oz and g...
I do recommend the racerstar motor and TGY servos... with gartt 2204-1800 motors being a good alternative
Jan 11, 2020, 01:56 AM
davereap's Avatar
Next week the testing continues using an 18" fat bodied disco vs a 19.5" fat bodied quasar v3..
NOTE...The v3 's curved wing was cut back to make a v2 straight edged wing, this cut back has made it an 18.5". so there is less difference..
I swapped the sunnysky for a new racerstar.. So now they both have the same motor/prop setups..
Remaining.....still obvious differences the two. the fat bodies shapes, and the wing shapes..
Jan 11, 2020, 12:08 PM
The reason I asked about the nose extension is I'm hoping to buy a foam kit from WMPF since I have no local access to decent foam...not even fff. I assume that kit probably won't have an extended nose.
Jan 12, 2020, 09:53 AM
davereap's Avatar
No the kit will be cut without any extension to the originals standard shape..
When I added an extension I had to extend the body as well to get a good fit..
r/cdawg...
?? have you made the drawings for your fuz yet??
Jan 17, 2020, 03:11 AM
davereap's Avatar
Yesterdays session was a bit of a disaster.. crash damages and an ESC playing up prevented me getting a good comparison..
Both sets of landing gear were ripped off as I hit the roof beams..
The damages were a result of not using my standard L/G build methods.. normally I would fit 3 full triangles going up the fuz and onto the wing.. fitting the legs to these triangles. on the disco I tried a shorter set and so lost the lot..
On the quasar I had tried an alternative fitting.. again this proved to be too weak..
while they flew they both went well..
Disco repairs done, the disco repaired has a stronger landing gear..pic3 and and both have a new ESC ...
edit...The quasar is now done , similar to the disco pic4
AUW ....disco 186g ..quasar 190g.. includes the 450 2s lipo.
Wing loading ...disco 3.7ozsqft..... quasar 3.6ozsqft.
Build Log BiPi a Twist on the Pi Plane dz1sfb Foamies (Scratchbuilt) 30 May 06, 2018 02:16 PM
Discussion Fake Hate Crimes: SJW's lie redux redux redux MtnGoat Life, The Universe, and Politics 7 Nov 21, 2016 05:45 PM
Discussion KF section UFO/Pi plane dekan Foamies (Scratchbuilt) 3 Sep 03, 2008 02:24 AM
Discussion pi Plane sr71fan Foamies (Scratchbuilt) 54 Jul 01, 2007 12:43 AM
