JTA Innovations News - New Motor and ESC!
Jase Dussia says - Hope you are having a great December so far! I wanted to inform everyone about a couple of additions to our offerings!
From Jase
Freshly received and just put in stock this week is the T-Motor AT2303 2300kv motor and the T-Motor AT-12A (12amp) ESC. Both of these products are available to accompany our current lineup of 6mm models. I have personally been flying with the 2303 motor recently on the 33 Gamebird and 33 MXS with a 2S pack, and that is more than enough power for me. Very happy with the performance both indoors and outdoors. Very happy to have these available along with our airframes, and please stay tuned for more electronics to come in the future! www.jtainnovations.com
T-Motor AT2303 2300KV - $34.99
Description
  • Brand Name: T-Motor
  • Series: AT Series
  • Color: Blue
  • Size: 2303
  • KV: 2300
  • Max Lipo Cell: 2S
  • No-Load Current (A/10V): 0.75A
  • Max Current(A)/180S: 9A
  • Max Power(W)/180S: 65W/2S
  • Motor Resistance(including line): 122mΩ
  • Recommended ESC: 10-15A
  • Outside Diameter: Short shaft¢28*16.5mm
  • Stator: Resistant to 150℃ high temperature coating
  • No. of Stator Arms/Poles: 12N14P
  • Shaft Diameter: IN: 4mm, OUT: 3mm
  • Bearing: Imported 684ZZ bearings
  • Magnet Level: Resistant to150℃ temperature
  • Wire Leading Spec.: Enameled wire leads 40mm
  • Wire Insulation Grade: Resistant to 220℃ temperature
  • Coil Insulation Test: 500V withstand voltage test
  • Centrifugal Cooling Method: ON
  • Rotor Dynamic Balance Standard: ≤5Mg
  • Motor Overall Dynamic Balance Standard: ≤10Mg
  • Dustproof & Waterproof: IP35
  • Weight (including wire): 17g
  • Package Weight: 43g
  • Application: Suitable for RC Airplane
T-Motor AT-12A ESC - $14.99
Specs
  • Model: AT-12A
  • Cont. Current: 12A
  • Burst Current: 15A
  • BEC Mode: Linear
  • BEC Output: 5V/2A
  • Battery Cell: 2-3S (LiPo), 5-9 cells (NIMH)
  • Weight: 11g
Get More Info
Head over to the site for more information.
New Product JTA Innovations 33 MXS JaseTheAce 3D Foamies 8 Feb 10, 2020 11:54 PM
Discussion JTA Innovations 33" Gamebird JaseTheAce 3D Foamies 13 Feb 06, 2020 12:20 PM
New Product JTA Innovations 32" Yak 54 JaseTheAce 3D Foamies 62 Aug 28, 2019 08:23 AM
Article Jase Dussia Announces - JTA Innovations! Jim T. Graham 3D Foamies 8 Aug 06, 2019 07:56 PM
Article JTA Innovations - 33" Gamebird Jim T. Graham 3D Foamies 1 Jul 24, 2019 11:33 PM
