Dec 14, 2019, 07:37 PM
sosam117
mcintmg's Avatar
Question
Thread size for K-Mills .75 crankshaft
Hello,
Does anyone know what the thread size is on the crankshaft of an Aurora K-Mills .75?
I need to tap a new spinner nut and don't know the thread size?
It is not Metric. I tried a 4mm and 3.5 mm nut and the 4mm is too big. the 3.5mm nut starts but stops after 1/4 turn.
It is not 8x32thd, the nut is loose and it looks like not the correct threads per inch? The 6x32thd nut does not fit at all.
I think it is an Imperial size thread but what size?
Thanks for the help,
Mike McIntyre
Dec 15, 2019, 06:21 AM
fiery's Avatar
4 ba.
Dec 15, 2019, 09:04 AM
Cougar429's Avatar
Quite a few used 1/4-28 or 5/16-24, with the much larger using 3/8-24. All these are fine thread.
I would strongly suspect yours is the 5/16 size.
Dec 15, 2019, 09:23 AM
GloBroz PowerLab
1QwkSport2.5r's Avatar
Read here: the other thread that answered the question already. https://www.rcgroups.com/forums/show...-75-crankshaft
Dec 15, 2019, 09:52 AM
sosam117
mcintmg's Avatar
Thread size on a K-Mills .75 diesel?
Thanks so much for your help -- all of you.
The camshaft diameter measured .1417 inches ( using a micrometer) so, ffkiwi is correct then the Mills .75 shaft thread is 4BA (British Association).
Thanks ffkiwi for the info below:
If you want to source the taps-you'll almost certainly have to go to a UK supplier-and you can't do better than Tracy Tools for the range of options on offer: www.tracytools.com
Discussion Thread size for K-Mills .75 crankshaft mcintmg Engines 3 Dec 15, 2019 05:31 PM
Discussion Crankshaft thread sizes on small diesels bogbeagle Engines 9 Sep 25, 2012 11:37 PM
Discussion Fuel for Mills .75 and 1.3 help please Jiffy Vintage & Old-Timer Designs 20 Jul 01, 2009 02:12 PM
Discussion Crankshaft size for an OS FS 91 S II ljasmann Engines 2 Feb 15, 2009 09:05 PM
Question Propellers for ED Baby and Mills .75 DeeBee1 Engines 5 Mar 08, 2008 03:27 PM
