Dec 13, 2019, 02:38 PM
gpw
gpw
“There’s no place like Foam”
gpw's Avatar
A New CANARD…
Well, for me anyway !!!
Gentlemen and fellow fliers , due to my habit of taking junk mail and folding little paper airplanes out of them to toss off the second floor balcony ( the Rutan test) . We went through a lot of the same old designs , but this one was very interesting . So interesting we decided to make a Foamie' out of it .
Starting with a nice STRONG folded triangular fuselage , ultra simple construction , and the fact that it really glides Great ( from the balcony ) makes it attractive for a quick weekend Foamie build .
I’m working on the plans right now and will post them when finished. I still have some Blucor and it should be a very Quick build … ;D
Here’s pics of the “paper model” …
Latest blog entry: Lost plans
Dec 13, 2019, 03:22 PM
Foamy and Glider fanatic
Blacky's Boy's Avatar
Nice!!
I've heard the tall tale of fighters being designed on the backs of envelopes but never out of the envelopes themselves.
Dec 14, 2019, 12:01 AM
XFM
XFM
eXperimental Flying Machines
Air Mail ?
Dec 14, 2019, 02:55 AM
1962 hit single recorded by American singer Elvis Presley
Return to sender!
Return to sender!
I gave a letter to the postman
He put it his sack
Bright in early next morning
He brought my letter back
https://genius.com/Elvis-presley-ret...-sender-lyrics
Dec 14, 2019, 05:28 AM
gpw
gpw
gpw's Avatar
Just to explain the logic of salvaged paper planes , think of it as saving Foam while the experimenting goes on.. This way I can experiment with hundreds of models without using up my precious Blucor stock …
Now , lets talk about that triangular fuselage. For years now we’ve experimented with foam fuselage shapes , mostly trying to improve the strength and stiffness of the structure . Turns out the triangular fuselage is easy to make and the strongest of all the shapes … AFAIK Not the prettiest of structures , but strong and light , and requiring no internal bracing …
Dec 14, 2019, 10:47 AM
Hey, watch this!
Raymond-leflyr's Avatar
Woo Hoo ! A new design from GPW ! I can't wait. I even have some ModelPlaneFoam staring at me - just waiting for the gentle touch of my scalpel.
Dec 14, 2019, 04:57 PM
gpw
gpw
gpw's Avatar
OK , Guys , here’s what I have so far and am going to build from … You can wait to see how mine turns out or just try one on your own …Any questions let me know .
Dec 15, 2019, 01:38 PM
skumgummi dave
Cool!
Dec 16, 2019, 07:27 AM
gpw
gpw
gpw's Avatar
First decision , do we want to “fold" the triangular foam fuselage , or do we want to to cut three separate pieces and glue them together …? I’s a simple structure .. All how we want to put it together .
If we cut it and angle the cuts right ( @ 45 degrees) it should fit perfectly together …If we fold it , a “window screening tool” or similar would be handy . ( and a little packaging tape )
We’ll make both and see how it works out .
Dec 16, 2019, 05:28 PM
skumgummi dave
Dec 18, 2019, 07:05 AM
gpw
gpw
gpw's Avatar
Here’s a drawing about “folding the fuselage “ . It could be suggested running a "blunt tip" or window “screening tool" to score /compress the fold lines for easier folding . For bare foam , I’d suggest running packing tape on the Outside of the fold which prevents the foam from tension splitting , and protects it during flights .
The tape also works for the paper skinned foams too .
Dec 19, 2019, 10:35 PM
Folded fuse. easy and rigid. It's a tight fit inside the 2" sides in fanfold. Battery may have to go on outside?
Dec 20, 2019, 06:29 AM
gpw
gpw
gpw's Avatar
LD&D, That looks real GOOD !!! If you don’t have room a bigger Fuselage ( 3” ) may be better . We always put the battery on the outside bottom so it could slide off in a crash and not take the nose with it … We never had any problems with that ...
Dec 20, 2019, 01:48 PM
Will make it work. Just a heads-up to others. Anxious to get it together. Maybe 2 1/2 " would be adequate for 950 mah 3s stick pack.
Dec 20, 2019, 04:05 PM
gpw
gpw
gpw's Avatar
OK, That's COOL … Since we stared off with a paper plane , there’s plenty room for Improvements !!! Did you test glide it yet … The CG should be ~ the front of the wing … test gliding is the best way we found to establish the CG. Tall grass or into the sofa …
Discussion New 3D printed Canard basicguy 3D Printed Planes 1 Dec 10, 2017 10:57 AM
Discussion New canard build question ninjasword71 Foamies (Scratchbuilt) 39 Aug 13, 2017 05:31 AM
Video Canard Addict's Giant Canard Glider rcflyer11 Electric Plane Talk 7 May 01, 2010 09:21 PM
Discussion Of canards and pusher props... (new Barracuda canard prototype) Rusty-Gunn Foamies (Scratchbuilt) 30 Mar 02, 2008 11:23 AM
new french canard bipe! bleriot 11 Scratchbuilt Indoor and Micro Models 5 Jan 26, 2004 08:11 PM
