This thread is privately moderated by Mad_angler1, who may elect to delete unwanted replies.
Dec 13, 2019, 10:28 AM
Bog Flusher Platinum Grade
Mad_angler1's Avatar
Announce
Ardupilot Critical Bug - Arducopter 3.6.12 Critical Bug Update Released
The Ardupilot team have announced an update due a critical I2C Storm bug being found in some versions of Ardupilot.
More Info https://discuss.ardupilot.org/t/copt...or-older/50130
In Copter versions 3.6.10 and Plane 3.9 or earlier thisI2C bug has the possibility to cause an Autopilot to lock up mid flight.
It is advised all users Upgrade Copter to 3.6.12 and Plane users install Plane 4.0 or later.
The Dev team state
Copter-3.6.12 has been released as the official default software for MultiCopters and Helicopters.
For those flying 3.6.10 (or earlier) the upgrade is Critical to avoid possible lockups due to I2C storms. These situations are rare but we have seen enough of them that we strongly recommend upgrading.
For those flying 3.6.11, your vehicle is probably safe but we still recommend upgrading to 3.6.12 because it includes a fix to another rare case of I2C storm lockups caused by extreme interference on the bus. We have one reported case which involved a serial port inadvertently connected to an I2C port.
The upgrade from earlier versions of 3.6.x should be relatively painless with no re-calibrations required unless you see pre-arm checks prompting you to do so.
The two new changes in 3.6.12 are in the ReleaseNotes 6 and copied below.
Fix ChibiOS I2C DMA error
COMPASS_SCALE param to allow manual correction of compass scaling
The second issue allows users to work around a compass scaling issue with the Hex Here2 GPS/compass unit. The Here2 compass unit’s scaling is off by about 17% meaning setting COMPASS_SCALING = 1.17 should improve accuracy. The accuracy can be checked before and after this change by:
fly the vehicle in any mode but ensure the flight includes chaning the vehicle’s heading
download the dataflash log and check the NKF4.SM values which are the compass’s “innovations” (the difference between the expected values and actual values). Lower is better so hopefully Here2 users will see lower values after setting the COMPASS_SCALING value to 1.17.
Note: beta testing of Copter-4.0.0-rc3 will resume next monday (Dec 16th).
Discussion Donate system now available to support Pixhawk/Ardupilot/ArduCopter development mike_kelly Multirotor Drone Talk 5 Jun 29, 2016 09:13 AM
Discussion Ardupilot Arducopter APM Pixhawk News mike_kelly Multirotor Drone Talk 13 Mar 27, 2016 10:08 PM
Discussion ARDUPILOT vs. ARDUCOPTER phil419mike Multirotor Drone Electronics 4 Dec 16, 2015 07:51 PM
Discussion Maxecuters photo page updated 12/6/15 Pat Daily Free Flight 3 Dec 10, 2015 01:28 PM
Discussion ArduPilot vs. ArduCopter: Is there a difference? servohead117 FPV Equipment 4 Dec 08, 2013 11:12 PM
