This thread is privately moderated by GroundControlRC, who may elect to delete unwanted replies.
Dec 13, 2019, 10:28 AM
Video
DustOff #2 - MinimumRC Nano F8F Rare Bear Stall Turn Practice
Here is a link to the Video:
https://www.youtube.com/watch?v=kkoFIZGiHWg
#GroundControlRC #GlueAndFly #ScratchBuildPlanes #MinimumRC #RareBear #F8F #Nano
I now have pretty good thrust with this Motor & Prop!
A Poster asked a question in a previous video of why I hadn't performed any Stall Turns?
Well, most of the Aircraft I have experience with do not have Rudders which makes it impossible to do a Stall Turn.
I've never attempted a Stall Turn so in this video I'm practicing Stall Turns.
Let me know if I did it correctly or really messed up ;-)
Here is a link to the Playlist which also includes the Build Tutorial Videos:
https://www.youtube.com/watch?v=Sq5F...ZQkvmPQdg4eW_M
You Can Help Support Us By Using Our Affiliate Link To The Product Below. A small commission (At No Cost To You) helps us buy more items to review.
Here is a link to the Pro PNP Version of this Kit:
https://www.minimumrc.com/f8f-rarebe...cer-p0016.html
*Banggood no longer has the Pro Version, however, you should be able to add another servo for the ailerons to get full 4 channels, this may require a MOD to the fuselage.
Also, the 3 channel comes with a 720 motor but I like the 1020 Motor ;-)
MinimumRC F8F Rare Bear 360mm Wingspan KT Board Mini RC Airplane KIT With 720 Coreless Motor - KIT+Motor+Servos
https://www.banggood.com/MinimumRC-F...47791920140372
MinimumRC Rare Bear Spare Props - Hole Diameter is 1.0mm
A Pair MinimumRC 75mm Propeller CCW For 716 8520 Coreless Motor
https://www.banggood.com/A-Pair-Mini...47791920140372
(1) MinimumRC 75mm Propeller CCW For 716 8520 Coreless Motor
https://www.minimumrc.com/75mm-propeller-p0034.html
Here is a link to the Receiver I used:
Here is a link to the Servos:
TY Model 1.7g Servo With JST 1.0mm Plug Compatible Spektrum 6400 Series Receiver For RC Airplane
https://www.banggood.com/TY-Model-1_...47791920140372
Here is a link to the Batteries I used:
5Pcs URUAV 3.8V 250mAh 40C/80C 1S Lipo Battery PH2.0
https://www.banggood.com/5Pcs-URUAV-...47791920140372
This LIPO may work even better as it's a bit lighter weight:
Sologood 3.8V 200mAh 80C 1S HV 4.35V PH2.00 Plug Lipo Battery
https://www.banggood.com/Sologood-3_...47791920140372
Here is a link to the 4pk of 1020 Motors & Props I used:
1.2mm Propeller and 1020 Coreless Motor Set for 90mm-150mm DIY Micro FPV RC Quadcopter Frame
https://www.banggood.com/1_2mm-Prope...47791920140372
See you in the Air!
Consider Supporting Our Channel by becoming a Patron at: https://www.patreon.com/groundcontrolrc
Patrons of the Channel will have Exclusive access to Aircraft Plans & Content!
See Us On Youtube | Patreon | RCGroups
