ARRMA 1/5 KRATON 4X4 8S BLX Brushless Speed Monster Truck RTR
The KRATON 8S BLX 4WD Speed Monster Truck stands out for more reasons than its huge 1/5 scale size. It's built for extreme bashing with ARRMA toughness, 8S capable brushless power, and a telemetry-ready Spektrum SMART radio system, motor and ESC.
The King of Kratons
The KRATON 8S BLX 4WD Speed Monster Truck stands out for more reasons than its huge 1/5 scale size. It's built for extreme bashing with ARRMA toughness, 8S capable brushless power, and a telemetry-ready Spektrum SMART radio system, motor and ESC. Experienced bashers can shred big-time with the 1/5 scale ARRMA® KRATON™ 8S BLX 4WD Speed Monster Truck. DESIGNED FAST and DESIGNED TOUGH, it’s ready-to-run out of the box and comes with nearly everything you need — just add your preferred batteries and charger. The supplied Spektrum™ DX2E Active® transmitter and SR6100AT AVC® (Active Vehicle Control®) receiver take full advantage of the innovative telemetry technology found in the included Spektrum™ Smart Firma™ brushless motor and ESC. Download the free Spektrum™ Dashboard App to your mobile device to view motor RPM, ESC temperature, receiver voltage, drive pack voltage and more data in real-time. Dial-in extra stability with the radio’s AVC® system to carve corners and nail jumps without letting up on the throttle. The KRATON 8S BLX 4WD is capable of 55+ MPH speeds in optimum driving conditions using an 8S LiPo (2 x 4S LiPo batteries) and optional pinion gear (available separately). The speed potential is amazing — and you’ll be able to use it all.
Features:
  • Laser-etched aluminum anodized chassis plate
  • Strong composite chassis side pods
  • Triangular structured center brace system for maximum durability
  • Oil-filled adjustable shocks with massive 20mm bore
  • Ultra-thick composite front and rear shock towers
  • Easy-access 3-bolt sliding motor mount for quick motor removal
  • Aluminum motor mount and hubs
  • Heavy-duty drivetrain
  • Durable steel driveshafts throughout
  • Easy-access front and rear diff module design
  • All-metal diff outdrives and gearbox internals
  • Easy-access waterproof electronics module
  • Heavy-duty dual spring servo saver
  • Multi-split spoke wheels
  • Durable wheel hubs for increased strength
  • Multi-terrain dBoots® COPPERHEAD™ 2 SB tires
  • Ultra-tough truck body and decals
  • High downforce wing
  • Integrated internal body protection tower
  • Spektrum™ DX2E Active® 2.4GHz Radio with SR6100AT AVC® Receiver
  • Spektrum™ Firma™ 160A Smart ESC
  • Spektrum™ Firma™ 1250Kv Brushless Motor
  • Spektrum™ S905 Metal-Geared Digital Servo
  • 2-year limited warranty
Check out the ARRMA 1/5 KRATON 4X4 8S BLX Brushless Speed Monster Truck RTR Here
Dec 11, 2019, 01:25 PM
Panhead5496's Avatar
This thing looks like a beast. I’ve seen some videos of people running it and it’s impressive. You do need a huge amount of space to run it at full potential however.
Dec 11, 2019, 09:36 PM
Wish they made the braces flat then round.looks home made to me
Discussion ARRMA 1/8 Kraton 6S BLX Brushless 4WD RTR bill34207 Electric Power Cars 58 Jun 29, 2020 09:25 AM
Discussion 1/8 Kraton 6S BLX Brushless 1/8 4WD Speed Monster RTR only arikair Vendor Talk 5 Jan 08, 2019 08:50 PM
ARRMA Kraton 6S BLX Brushless 1/8 4WD Speed Monster RTR arikair Vendor Talk 0 Jan 02, 2019 02:30 PM
ARRMA Kraton 6S BLX Brushless 1/8 4WD Speed Monster RT arikair Vendor Talk 0 Jan 02, 2019 02:26 PM
New Product Arrma Nero BLX 6s 1/8 Monster Truck Jym73 Off-road Cars 2 May 29, 2016 02:34 PM
