Dec 07, 2019, 12:51 PM
FA3PR9WM79
Oldgazer's Avatar
How to mount a MAUCH Battery Monitor...
I have wanted a MAUCH battery monitor for a long time. Yesterday I finally got one. I plane to use it on a slightly stretched Tarot 650 Sport. I'm running 6S. I have the BM in an enclosure. I am using a MAUCH BEC.
The problem is, I can't figure out how/where to mount the silly thing.
Before I was using the ubiquitous 3DR style BM and I could slip it between the mounting rails above the battery and every thing was tucked in and out of the way, and the battery connection was at the rear of the frame.
With the MAUCH BM, every thing is backwards.
I suppose part of the problem stems from the fact that this frame has the PDB circuitry integrated into the UPPER plate at the rear of the frame. This means that any form of current measuring device must be placed between the PDB and the battery, and the way the MAUCH is designed, this means the battery plug must be at the front were it will interfere with my 3 axis gimbal.
The other issue is with the current/voltage sense and +5 volt feed cable between the MAUCH and Pixhawk. The short version is the cable that came with the MAUCH is only half as long as the one that comes with a generic 3DR style BM, so to connect the MAUCH to the Pixhawk I'd have to mount the MAUCH on the top plate.
At this point I am totally disappointed because to get this to work I have to re-engineer the entire battery system. Not what I wanted to spend my weekend doing...
Dec 10, 2019, 01:45 PM
FA3PR9WM79
Oldgazer's Avatar
I finally got it shoe horned in between the battery plate and the lower plate. Had to completely rewire it.
Discussion How to mount batteries on a micro? neptune5 Micro Multirotor Drones 1 Jan 09, 2017 05:35 PM
Question How to mount the Spektrum 4.3 inch video monitor to DX6e? Air Wizardo FPV Equipment 2 Nov 10, 2016 10:17 AM
Discussion FPV Monitor Slide Mount - How to use it? nordemoniac FPV Talk 1 May 30, 2016 09:15 AM
Help! How to monitor 2 batteries ? ben5757 FPV Equipment 1 May 05, 2016 03:28 AM
Discussion LIPO puff how mauch is normal Arkx400 Batteries and Chargers 3 Mar 06, 2010 10:21 PM
