I would wait and pass on those beta connectors... |
I'm already pretty invested in the BT2.0's and don't really have any real complaints other than availability.
Any update on the BT2.0 alternative?
Nick Burns just reviewed the new us65 pro with the gnb27 plugs. Where are these things?!
Can't those plugs accidentally short two battery packs together if they're in a bag or box together? Having a terminal exposed on a battery seems sketchy. |
?? they're just like the BT2.0s , or an XT for that matter. Just a different shape for the plastic part for the most part. The back side of the connector needs heat shrink (or some sort of plastic cap, like on an XT90) after the wires are soldered on, or the terminals are exposed and can indeed be shorted out. The only hobby connectors that don't have that issue, far as I know, are ECs or Anderson Power Poles.
I suppose, I'm not saying they're ideal but they were cheap and available so I just got them figured they'd be better then the jst rcy's and at the time the bt2's were hard to come by. It seems like the gnb27 connectors would shave off 1/5 of a gram compared to the micro deans I'm sure they'd probably put out more amps and connect alot better
I've been using the deans micro on a wide range of rc batteries going on 15+ years now and never had a single one short because of that. And I don't take any special precaution, I store my lipos just dumped in a battery box. To short you need to contact both sides, only one is exposed.
I still haven't tried on 2s but I suspect they have to be better then the jst rcy's, I built a 1s toothpick up with 1202.5's and the micro Deans don't seem to be holding it back
Thread Tools | |
Similar Threads | |||||
Discussion | DIY 2-axis Gimbal Controller. What's the latest consensus on controllers? | AeroMaestro | Multirotor Drone Talk | 1 | Dec 06, 2016 07:12 PM |
Discussion | What's the general consensus on the purchasing experience from gearbest? Hit/Skip? | day o | Beginner Multirotor Drones | 2 | Sep 23, 2016 11:43 AM |
What is the general consensus on connectors? | Kevinfred | Batteries and Chargers | 51 | May 19, 2016 08:06 PM | |
Question | Cyclon Brushless outrunner motors - What's the consensus? | Aio_1 | Electric Power Systems | 87 | Jul 22, 2006 12:05 PM |
What's the consensus on the Hummingbird? | uglyplane | Micro Helis | 3 | May 23, 2003 02:20 PM |
