Dec 16, 2019, 10:22 AM
Sealed up the foam. Now on to filling.
Dec 16, 2019, 07:48 PM
First drywall on.
Dec 17, 2019, 12:03 PM
GET BACK IN THE SHOP!!!!!!
CaptDH's Avatar
I run 3 of the same units Bob suggested with the same motors. No need for water cooling on that motor. TRUST ME!! I run it full throttle pulling barges and the motor doesn't even reach body temperature. You will probably need to cool the ESC's and that is quite easy with the KMB jet drive. It has a built in port to pull water through the cooling system. Check out some of my builds to see the process...
https://www.rcgroups.com/forums/show...-scratch-build
https://www.rcgroups.com/forums/show...ib-rescue-boat
DH
Dec 17, 2019, 02:40 PM
Thanks CaptDH
Great stuff.
Dec 17, 2019, 07:38 PM
A little more work. You just start to see the chine.
Dec 17, 2019, 08:42 PM
Latitudes vs Attitudes
Bob Gaito's Avatar
Man I am enjoying watching this build... But please use a 6-inch putty knife and follow the frames.. things will go a lot easier for you... Start at the keel pull to the Chine start at the chine and pull to the gunnel... Use the plastic credit card for the final fill... It would save you soooo much sanding.
Latest blog entry: Titanic Boarding Pass
Dec 17, 2019, 10:15 PM
Na. I like to here you suffer. LOL
But I have a hole gallon of drywall filler ?
Still working things down .
Dec 18, 2019, 12:39 PM
Some work on the transom.
And all hull sanded again. LOL
Dec 18, 2019, 04:20 PM
CaptCB's Avatar
Please note:
In the photo you have next to the plug you are making, both the transom above the knuckle, and the openings for the jet drives, are not correct, as they have been modified.
There are other better, correct photo's around anyway.
Dec 18, 2019, 05:10 PM
Bob Gaito's Avatar
Hmm-the differences are subtle, I guess I don't really see it except for the exhausts or maybe scuppers
Dec 18, 2019, 08:26 PM
It was more the shape.
Also put the third layer of drywall on. Maybe one or two more ?
As for the jet outlets this is just how long the boats were in use.a jets being updated.
And the jets will not be a model used on the boats during Nam.
And the motors got here today. Now I need the jets. Germany is so far away .
Also have over 100+ photos of the boat. But thanks for posting them.
Dec 18, 2019, 08:55 PM
Bob Gaito's Avatar
What style reverse is did you go for, KAMEWA or Riva calzoni ?
Dec 18, 2019, 09:07 PM
The KMB 28 ,you let me know about.
But I went with the 100 amp ESC. Maybe over kill but ???
Dec 18, 2019, 09:08 PM
Bob,how did you wire the motors ?
Dec 18, 2019, 09:09 PM
Bob Gaito's Avatar
Yes the KMB 28 comes with a choice of reverser type or no reverser at all-just curious but I can wait and see.
Help! Help needed on first ever RC build (Nutball scratch build) New Tomi Beginner Training Area (Aircraft-Electric) 8 Mar 05, 2018 09:06 PM
Discussion Building a telemaster 66 (my first build). Need help selecting a few things. helifrek Fuel Plane Talk 68 Sep 28, 2017 06:53 AM
Discussion PBR Help HowBau Scale Boats 7 Sep 01, 2016 09:52 PM
Discussion 1:18 pbr mark 1 build thread CaptDH Scale Boats 70 Nov 18, 2013 08:20 AM
Question Tamiya Intl. mag 1991 PBR build article vintageone Scale Boats 0 Apr 15, 2007 05:01 PM
