New Product
The NEW E-flite Twin Otter 1.2m BNF Basic/PNP...Versatile and Easy To Fly Scale Twin!
See more info below and on the product pages via this link:
https://www.horizonhobby.com/SearchD...ain=&pageView= Introduction VERSATILE AND CAPABLE The DHC-6 Twin Otter was developed by de Havilland Canada in 1965. Designed as a rugged STOL (Short Take-Off and Landing) commuter aircraft, the Twin Otter carried passengers and cargo into harsh environments such as the sub-zero Antarctic and scorching North African desert. The line was shut down in 1988, after producing 844 aircraft. Viking Air Limited purchased the Type Certificates for all out-of-production de Havilland aircraft in 2005 and announced the Viking Series 400 Twin Otter Production Program two years later. By mid-2015 Viking delivered 75 new aircraft and re-established the Twin Otter as a successful commuter airliner — while nearly 500 of the original aircraft also remained in operation. The E-flite® Twin Otter 1.2m is a scale replica that makes the perfect first twin-powered model for intermediate to experienced RC pilots. It’s versatile, easy to fly, and is outfitted with functional features that include LED navigation and landing lights, flaps, and optional-use floats. Overview THE PERFECT FIRST TWIN For RC pilots who want a great first (or next) twin model, there’s no better choice than the E-flite® Twin Otter 1.2m. It delivers exciting “bush plane” scale looks and performance along with the inherent stability of a high-wing design. The convenient size of the Twin Otter means you can transport it fully assembled for flying at a wide variety of locations with paved, grass or packed dirt surfaces, such as large parks, sports fields and RC flying fields. Your adventures won’t stop there, though — remove the tricycle landing gear, install the provided floats, and now you’re ready to fly off of large ponds and small lakes. Having two landing gear options included in the box only hints at this model’s incredible value. Along with molded-in panel lines, corrugated control surfaces and a scale-inspired trim scheme, the E-flite Twin Otter comes with many functional features including operational flaps, LED navigation and landing lights, and props finished with black and white stripes that look awesome whether spinning or standing still. The Twin Otter 1.2m offers a truly unique flying experience that a wide range of pilots can enjoy. Twin Power The factory-installed power systems feature high-power brushless outrunner motors equipped with three-blade counter-rotating propellers. The ESCs are wired so they can be powered with a single 3S 2200-3200mAh battery to deliver better-than-scale power and long flight times of up to 10+ minutes. Versatile Gear Options Equipped with tricycle landing gear that includes a steerable nose wheel, the Twin Otter offers excellent ground handling and can be flown from paved, grass or dirt surfaces. You can also fly from water using the included float set — it matches the trim scheme and features a water rudder for superb steering control. Both gear options are easy to install and can be swapped out in minutes. Functional Features The realistic-looking LED landing and navigation lights are factory-installed and powered from the flight battery. Operational flaps offer improved slow-flight capability and performance while also making it possible to take off and land in shorter distances and at slower speeds. Durable Design Construction with molded EPO material makes it possible to replicate complex details and shapes in a lightweight yet durable form. The result is an outstanding scale appearance that’s easy to maintain and delivers the best flight experience possible. Bind-N-Fly® Completion Level Advantage Already own a Spektrum™ transmitter? Bind-N-Fly (BNF) aircraft make getting into the air quickly and with the best control experience possible easier than ever. They come out of the box with the power system, servos and a Spektrum 2.4GHz receiver installed so all you need to do is bind the receiver to a compatible transmitter, finish any final assembly and fly! This Bind-N-Fly Basic model is equipped with a Spektrum 2.4GHz DSMX® receiver featuring AS3X® (Artificial Stabilization–3-aXis) technology that works behind the scenes to smooth out the effects of wind and turbulence so you enjoy a sense of stability and precision that makes it feel like you're flying a much larger, expertly tuned aircraft. If this is your first model of its type, or you want an extra margin of safety while familiarizing yourself with the airplane, you can enable the optional-use SAFE® Select flight envelope protection technology built into the receiver. No programming is required. Simply change up the binding sequence as directed in the manual. With SAFE Select enabled, you get: Pitch and Bank Angle Limits • These envelope limits keep the airplane from rolling or pitching upside down. They also prevent excessive climb or dive angles. Automatic Self-Leveling • The airplane instantly returns to and holds level flight when the sticks are released and in the center position. It’s also helpful for keeping the wings level during takeoffs/launches and landings. Easy Switch Assignment—No Programming Required • The simple procedure for assigning a transmitter switch to turn SAFE Select features on and off doesn't require any programming and takes just a few seconds. If you don’t want to enable the SAFE Select features, just bind the receiver normally and it will function like a standard AS3X receiver. Plug-N-Play® Completion Level This Plug-N-Play (PNP) model comes out of the box with a factory-installed power system and servos that are ready to connect to the compatible receiver of your choice (sold separately). Simply install the receiver, finish any final assembly and fly! Key Features • Scale replica of the STOL (Short Take Off and Landing) capable cargo and passenger carrying utility aircraft • Easy to take off, fly and land, making it a perfect choice for a first twin-powered model • Functional features including LED navigation and landing lights plus operational flaps • Scale details including molded-in panel lines, corrugated control surfaces and more • High-power brushless power systems with striped 3-blade counter-rotating props • A single 3S 2200–3200mAh battery delivers excellent power and long flight times • Spektrum™ AR636 6-channel receiver with industry-leading 2.4GHz DSMX® technology (BNF® Basic version only) • Easy to fly with innovative and optional-use SAFE® Select flight envelope protection (BNF Basic version only) • The unmatched stability and locked-in feel of exclusive AS3X® technology (BNF Basic version only) • 5-Channel control with six (6) factory-installed servos and linkages • Tricycle landing gear with steerable nose wheel for easy ground handling • Includes matching optional-use floats with steerable rudder for flying from water • Conveniently sized so it can be flown at soccer fields, large parks and in other suitable areas • Easy to install/remove one-piece composite-reinforced wing with thumbscrew and snap-in struts • Magnetically-secured top hatch for quick and easy access to the battery compartment • Lightweight and extremely durable composite-reinforced EPO airframe • Extremely fast and easy assembly Specifications Wingspan: 48 in (1219 mm) Length: 36.75 in (933 mm) Flying Weight: 37-39.5 oz (1049-1118 g) Motors: (2) Brushless (installed) Speed Control: (2) 20A Brushless (installed) Servos: (6) Sub-Micro 9g (installed) Radio: Full-Range 6+ Channel Spektrum™ DSMX®/DSM2® Compatible (sold separately) Receiver: (1) Spektrum AR636 6-Channel Receiver (installed; required for PNP version) Battery: 3S 11.1V 1800–3200mAh LiPo with EC3™ or IC3™ Connector (sold separately) Needed to Complete • Full-range 6+ channel Spektrum™ DSMX®/DSM2® compatible transmitter (5+ channel transmitter/receiver for PNP version) • 3S 11.1V 1800–2200mAh LiPo with EC3™ or IC3™ Connector • Compatible LiPo charger |
Looks like invasion strips. Maybe a P-38 or DC-3,
Will skiis be an option too?
![]() If it is a Twotter I hope it's a round-nose Series 100. |
Ive got a VQ models Twin Otter and floats, but the project stalled out and its been packed away for quite a while. Would be neat to have a BnF Twin Otter. I missed the boat on the Hangar 9.
Latest blog entry: From the CC Paint Shop
Keep an eye out. A lot of them are starting to come around for sale for around the $600 mark. That seems to be the sweet spot for them. The H9 Twotter thread's been exploding lately with people getting their hands on used models.
I am hoping for a big Aero Commander!
Latest blog entry: Replacement Retracts for the 1400mm FMS...
Is it foam or built up?
I'm in!
![]() Joel |
Latest blog entry: Eflite 2.1m Carbon-Z Cub SS
Thread Tools | |
Similar Threads | |||||
Article | The NEW E-flite Timber X 1.2m BNF Basic/PNP - Get STOL3D! | Jason M | Electric Plane Talk | 4109 | Jan 23, 2021 11:22 PM |
New Product | E-Flite Timber 1.5m BNF Basic/PNP | Mattfly | Electric Plane Talk | 17501 | Jan 22, 2021 12:25 PM |
New Product | The NEW E-flite TURBO Timber 1.5m BNF Basic/PNP | Jason M | Electric Plane Talk | 1542 | Jan 21, 2021 08:30 PM |
New Product | The NEW E-flite Su-30 Twin 70mm EDF BNF Basic/PNP | Jason M | Foamy EDFs | 138 | Jul 18, 2020 11:03 PM |
New Product | E-Flite Clipped Wing Cub 1.2m BNF Basic and PNP | Micubano | Parkflyers | 16 | Feb 08, 2018 01:04 PM |
