D88 Foldable Brushless Drone with 2K Camera
Compact foldable fuselage, 2K Full HD 5G WIFI camera, brushless motors, with beginner/expert flight modes.
Potensic D88
Turn your attention up or down without having to adjust your altitude, just use the D88's one-axis gimbal to capture clear, stable footage at any level. Simultaneously charge two batteries quickly and safely using the included upgraded charger. A full charge takes four hours for two batteries (second battery not included).The D88 Drone's 3400mAh high-capacity battery will keep you flying for longer, with flight times of up to 20 minutes.
Dot-To-Dot Flight
Draw dot-to-dot on the Potensic app's built-in map to plan the drone's flight path, whilst overseeing its exact positioning via GPS.
Point of Interest
Found something interesting? Select it on the map and the D88 will fly clockwise around it, capturing crystal-clear, comprehensive footage.
5G WiFi Transmission
5G WiFi transmission provides real-time, seamless, high-clarity, first person views straight to your smartphone, allowing you to sit back and enjoy the ride.
More Info
Learn More
Head over to Potensic for pricing and more info.
Dec 07, 2019, 11:16 AM
nope
Dec 14, 2019, 03:04 AM
Internet Pilot
fATAL's Avatar
LOL! I thought it was using stepper motors at first!
Discussion Eachine EX3 Foldable 2K Camera GPS Drone with Optical Flow & Ultrasonic Sensors DG_Soarer Multirotor Drone Talk 3 Jul 29, 2019 09:53 AM
