This thread is privately moderated by mikey1372, who may elect to delete unwanted replies.
Dec 02, 2019, 06:28 PM
Trader Rating: 11
RC Plane addict.
mikey1372's Avatar
$25.00 USD
Seller Pays Shipping
Sold
Value hobbies Motor
Value Hobbies GFORCE 5065 400kv motor has some small scratches but works just fine $25 shipped .
The G60 (50-65) brushless out-runner motor can replace a .60-.75 two stroke nitro engines. It is equivalent to AXI 4130 and E-Flite Power 60. It is capable of producing up to 10lb of thrust and generate about 1200W of power.
Specifications:
KV: 400.
Weight: Approx. 14.6oz (414g) for motor only, not including mounting accessories.
Motor Diameter: Approx. 50mm
Shaft diameter: 8mm
Connector: 4mm bullet connector
Max efficiency: Approx. 50A
Max Load: Approx. 60A
Motor Dimensions:
Recommended Setup:
80A Opto brushless motor ESC
6S LiPO and at least 4000-5000mAh.
Prop Selection: Remember to always use props designed for electric motors, nitro props are heavier and might overload the motor.
With 6S LiPO: 16x10, 15x10, 14x10
The above prop selections are recommended for sports flying at open throttle. You may use slightly larger props if you do not fly at constant open throttle.
Dec 02, 2019, 06:35 PM
Trader Rating: 39
AMA 424553
RRHandy's Avatar
Mikey, I will take it.
Dec 02, 2019, 06:47 PM
Trader Rating: 11
RC Plane addict.
mikey1372's Avatar
I sent you a PM with my PayPal.
Sold Value Hobby Edge 39" PNP + batteries + spare motor cdbs Aircraft - Electric - Airplanes (FS/W) 0 Apr 14, 2018 03:47 PM
Discussion Hope I didn't make a mistake buying a value hobby motor spencer911 3D Foamies 5 Sep 11, 2016 12:15 AM
Discussion Value Hobby motors and batteries MagicMike Power Systems 10 Dec 09, 2009 01:02 PM
