This thread is privately moderated by shawn45, who may elect to delete unwanted replies.
Dec 02, 2019, 04:28 PM
Trader Rating: 4
$40.00 USD
Buyer pays shipping
Sold
GECKO 65A "NEW " with programming card
This is a high quality ESC and brand new!!! It is 65A with SBEC 8A. Here are some specs from Motion RC;
ZTW Gecko 65A ESC with 8A SBEC with XT-60 Connector - ZTW4065201
This ZTW Gecko series ESC is a high-quality, efficient brushless electronic speed control with an integrated switch-mode BEC. It can operate without the need for a separate receiver battery to power your servos and receivers saving you weight and simplifying your electronic connections. The Gecko series includes an aluminum heat sink body which is lightweight and helps dissipate heat more efficiently. The BEC on the Gecko has been specifically designed to support higher current applications to eliminate the possibility of unwanted shutdowns, and it is also capable of supporting simultaneous multiple servo operations typically found in large-scale airplanes and CCPM equipped large-scale 3D helicopters. If you are looking for a top of the line, full-featured ESC at a competitive price, the ZTW Gecko is the logical choice.
FEATURES:
Data logging system such as temperature, voltage, current, and RPM
SBEC Voltage Output 5.0, 6.0, 7.4, and 8.4V
Advanced Governor Mode and soft start
High SBEC Current Output, continuous 8A and burst 16A, designed to meet your high current applications
Power arm protection, over-heat protection, low-voltage protection and lost-signal protection
Secondary sub-menu setting by the LCD program card or your PC
Super smooth and accurate throttle linearity
Support for most motors, including high RPM motors
Programmable motor timing
Utilizes new smaller MOSFET technology to minimize weight
Aluminum finned heat sink
Programmable throttle input range
Anti-spark circuitry (on HV OPTO models only)
ESC firmware and program settings can be updated via PC connection (USB adapter sold separately)
INCLUDES:
ZTW 65A ESC with 8A SBEC
Pre-installed XT-60 Connector (power connector) and 3.5mm bullet (motor connector) for your convenience
Instruction Manual
OPTIONAL:
ZTW LCD Programming Card - More Info
WiFi Programming Module - More Info
PRODUCT SPECIFICATIONS:
Length
66mm / 2.59in
Width
33mm / 1.29in
Height
16mm / 0.62in
Weight
67g
MAX Output
Continuous Current 65A
Burst Output
85A (10s)
Battery
5-18NC/2-6Lipo
BEC Output
5.0V 6.0V 7.4V 8.4V Adjustable/8A
Power Connector
XT-60 Connector
Motor Connector
3.5mm bullets
Discussion Do you program those new small blheli ESC like the old ones with programming card? FlyingPancake Multirotor Drone Power Systems 9 Jun 08, 2016 01:35 PM
Sold Gecko 85amp esc and programming card Chad White Aircraft - General - Radio Equipment (FS/W) 3 Mar 08, 2016 11:45 AM
Sold Gecko 85amp esc and programming card like new! Chad White Aircraft - Electric - Helis (FS/W) 0 Mar 06, 2016 09:38 PM
Sold Gecko 65a ESC, Brand new, with LCD programmer new user Aircraft - Electric - Power Systems (FS/W) 6 Oct 12, 2015 05:14 AM
