Nov 29, 2019, 10:30 AM
Build Log
"Draken"-inpired foam deltawing
Hi! I Will post some pictures off a small side project:
The material is 10 and 5 mm foam sheets.
Edges and rudder of 10 mm balsa.
The body is reinforced internally with 3 mm balsa.
The motor mount is balsa / plywood laminate.
The span is 960 mm and the length of the body 870 mm.
The engine is Turnigy Aerodrive SK3 - 3542-1185kv which is mounted in the nose.
https://www.hobbyking.com/hobbyking/s...dProduct=18120
Propeller probably 11X7 or 10X7 to start with?
Cruise control TURNIGY Plush 60 amp.
Two Hitec HS82MG for alerions and one HS65 for rudder.
Battery 4S/4h Lipo. Target weight 1500 gr and wing Surface aprox 29,8 dm2.
The covering is thin self-adhesive vinyl from the local hardware store, Bauhaus.
They have plastic in all colors and shapes at good price so im going to test it on this build.
// Mats W
Nov 30, 2019, 05:51 PM
Cowering is now ready.
Motor and rudders is mounted.
Only servos and linkage left:
// Mats W
Discussion Clausxpf/Air Sally J-35 Draken,Alpha/Beta build w/New foam shell & glass method AIR SALLY Scratchbuilt EDFs 1212 Sep 27, 2019 12:44 AM
Download New 15 Detailed Review about Inpire 1, Scout X4 and Voyager 3 BeginnerBR Other Websites 0 Mar 09, 2015 03:10 PM
Build Log clausxpf Foam Shell & Glass 70mm Draken - Maiden Flight Video Up! bwoollia Scratchbuilt EDFs 234 Feb 07, 2015 11:31 PM
TSK 60 Electric Conversion (inpired by Albig) mitc99kd Electric Heli Talk 6 Nov 21, 2002 02:25 PM
