You can download dat files of many airfoils at http://airfoiltools.com That should get you started.
This is a java program. You need to install java on your system. Its free.
Hello All
First, well done Dodo3441 for this small piece of software, very usefull to prepare Gcode file. UNfortunatly with the enclosed file not working. Don't know why. It opens well but the profile is not complete. Just check with excel graphs and what is dispayed with WingWire. FIle should be renamed as .dat file. Any ideas? Thanks for your help. |
The text file is not parsed into two columns. I dropped it into excel and parsed it and got a very strange chart. It looks like you have also got you x and y columns back to front. I changed that and it looks like you are trying to make an elephant shape with extra squiggles in Excel. Remember that wing wire has a smoothing routine to give efficient Gcode. It does not respond well to a file that jumps around. The data file must be sorted into x coordinate order with the highest x coordinate usually 1.000000 first. to conform to the .data format. If you want to cut irregular non wing like shapes wing wire is not the best choice. It is designed for wing type shape and smooth curves. Other threads in the Cad Cam will give you some ideas. Hope this helps |
OK. Thanks for your answer. I will try with X 1.0000 first.
For your understanding, if you import the file into excel choose space as separator. Then tou have to remove the second column that will most probably appears with a point. After that you should get something like the enclosed screeen capture. This is a wing separate (top is missing to lower number of point replace with a straight line). Wing is separated in 2 halves to make remove weigth. The shape you see are made to imbricate together when you put bottom and top together. Ie : if you shift virtually the bottom part to right you will see that they fit together to be only oneHope it is clear for you ![]() At the end this is a wing ![]() I don't understand why it should not work as it seems that this soft translate XY/UV shape to XY / UV Gcode? Regards. |
I got the same as you in Excel. I can get the profile to load in Wingwire and get some similar shapes, but a lot of distortion at the leading edge and the trailing edge. I think it is the inbuilt smoothing algorithm in wing wire that is struggling. The algorithm was developed for conventional wing shapes by Dr Mark Drela. It interpolates extra points where required to ensure matching numbers of coordinates for the root and the tip with the sort of spacing that suits the assumptions built into gcode. Your coordinates move backward and forward across the x axis in a manner not expected by the algorithm.,
Try dividing your coordinates to just cut the top surface . This may indicate if a simpler coordinate grid can work. How did you generate the coordinates.? |
I can't seem to find any dat format this program likes??? I downloaded several directly from here:
http://airfoiltools.com/search/index...D=1&yt0=Search I tried both Selig Format dat files and Source Format dat files, the only choices available. Neither will load. Here are a couple I tried. I had to change the dat extension to txt to get them to upload. Tom |
J |
Thanks for sharing!
I've just completed my cutter Dodo posted on Thinggiverse. Great little machinery! Big thanks. I use it with a standalone GrBl/Arduino/Ramps-setup I found here https://github.com/ThomasHeb/4AxisFoamCutter
So - now I can use the Wingwire app to design cuts on my mac, export it to SD-card and go down and cut in my computer-free cave. I'm very grateful for this! |
Thread Tools | |
Similar Threads | |||||
Discussion | JPEG to Gcode for arduino/ramps 1.4? | RaceMag | CAD/CAM | 11 | May 19, 2018 04:51 AM |
Discussion | getting gcode on both turrets 4axis wire cutter | Blackrat | CAD/CAM | 2 | Oct 14, 2011 11:41 AM |
Question | dxf or dwg to Gcode converter | Edu_ns | CAD/CAM | 4 | Mar 17, 2011 10:02 PM |
New Product | CNC Workbench foamcutting software with GCode | [email protected] | CAD/CAM | 9 | Feb 10, 2011 05:26 AM |
