Nov 27, 2019, 09:41 AM
Download
WingWire | 4 axis gcode freeware
Hey everyone,
after building a ardiuno based 4-axis machine earlier this year I realised that there are very few options when it comes to freeware that can create gcode for wings. Since none of the options worked just the way i wanted to I started working on my own. The result can be seen here:
WingWire | Free 4 axis foam cutting gcode software (5 min 37 sec)
Whilst I do not plan to expand the program further as it is very time consuming and it does what I need it to do feel free to discuss possible improvements if you have any, some might be easy to implement and I'll get around to doing so at some point.
Versions
_____________
Version 1.00
Version 1.01
- Added single wing mode
- Fixed export path memory
Nov 27, 2019, 07:57 PM
Ward Hagaman's Avatar
Wow, very impressive, AND generous of you to share!
Nov 28, 2019, 05:19 AM
Fantastic work. Well done.
Perfect timing for me as I too have just finished a Arduino/Ramps1.4 Hot Wire set-up and had started to look at various designs for the mechanical side of things. Your design fits the bill perfectly!
Couple of questions for you:
1. Re the 3D printed parts. Are you printing these solid or with an infill %?
2. I assume you are connecting the vertical lead screws to the motors with 5mm to 8mm couplers?
Software Suggestion
The only thing that I would like to see added is the ability to include spars where you can define the size/position from either below or from the top of the wing. (Single "U" channel from the bottom of the wing in my case). Ditto 5mm dia hole for servo wires.
Thank you for sharing this.
Nov 28, 2019, 05:34 AM
1. Petg with 20% Infill I think, or something along those lines.
2. The stepper motors came with integrated lead screws, so there is no coupling.
Nov 28, 2019, 06:12 AM
Thanks for the quick reply.
I didnt know you could get Nema17 motors with the lead screw already integrated.
One other thing I meant to ask is how many teeth did you go with on your GT2 drive pulley's?
Nov 29, 2019, 04:57 AM
software
hi nice work and thanks for sharing what software are you using to drive your arduino based cutter i am in to cad so if i can help just pm me
Nov 30, 2019, 09:15 AM
should be a 16 tooth
GRBL Hotwire controller
Dec 07, 2019, 05:17 AM
Hi
I've now built your hot wire cutter as per Thingyverse. Looks great and slides a treat. Hoping you can help me with another couple of questions:
1. Can you tell me the step/mm values you ended up using on your horizontal and vertical axis.
2. Once I have carried out the "config.h" change "ALWAYS_DEFAULTS_SETTINGS" to 0, will I be able to thereafter just make any further changes in the Grbl Settings Tab and will they stay the defaults even after closing Grbl or will I have to change the setting each time in the Arduino program and upload the sketch again?
3. Driving the hot wire from the RAMPS board works fine with my smaller bow but my longer bow needs 16-17v 5-6A to get it to the right temperature. (Im currently using a 12v 30A power supply). Can I use a 24v power supply to the Arduino/Ramps board without altering anything? I see there are lots of Youtube vid's showing how to "Upgrade" the Ramps board to allow a 20v power supply and others saying it can handle 20v as is.
Thanks.
Dec 08, 2019, 09:02 AM
24V with Ramps 1.4 questions You can usually run more than 12V into the RAMPS board, BUT you need to beware of the voltage from RAMPS that gets fed into the Arduino Mega.
Dec 08, 2019, 01:54 PM
Hi
Thanks.
1) my step/mm values: Vertical:400 Horizontal:80
2) 0 = you can change them in the settings tab and they will be saved 1= it will always use the defaults set in the sketch
3) Not sure, I ended up using an external power supply because this maintains the same current regardless of wire lenght. I think I read that some people go up to 48V on ramps but im not sure, take a look at the arduino/ramps1.4 thread.
Dec 11, 2019, 01:44 PM
Thanks for the info.
Cutter now working well and providing some very nice cuts.
Is there any chance you will at some point in the future update your software to include the ability to include placement/sizing of Spar channels and servo wire holes?
Dec 26, 2019, 05:06 PM
update
version1.01 allows cutting single wings.
( Configure the left wing and gcode for both left and right wings will be generated. )
Feb 03, 2020, 10:35 AM
Kevin Matney's Avatar
What drive board will it run?
Feb 03, 2020, 10:36 AM
This program just generated the gcode, I use it with GRBL Hotwire controller + Ramps 1.4.
Discussion JPEG to Gcode for arduino/ramps 1.4? RaceMag CAD/CAM 11 May 19, 2018 04:51 AM
Discussion getting gcode on both turrets 4axis wire cutter Blackrat CAD/CAM 2 Oct 14, 2011 11:41 AM
Question dxf or dwg to Gcode converter Edu_ns CAD/CAM 4 Mar 17, 2011 10:02 PM
New Product CNC Workbench foamcutting software with GCode [email protected] CAD/CAM 9 Feb 10, 2011 05:26 AM
