This thread is privately moderated by Merch, who may elect to delete unwanted replies.
Nov 27, 2019, 08:28 AM
Merch's Avatar
Mini-Review
Happymodel Mobula6 65mm Crazybee F4 Lite 1S Whoop FPV Racing Drone BNF Runcam Nano 3
Only 20g Happymodel Mobula6 65mm Crazybee F4 Lite 1S Whoop FPV Racing Drone BNF w/ Runcam Nano 3 Cam - 19000KV FrSky Receiver
Runcam Nano 3
Mobula6 spares
Happymodel Mobula6 65mm Crazybee F4 Lite 1S Brushless Whoop FPV Racing Drone BNF
Specification:
Brand Name: Happymodel
Model: Mobula6
Item Name: 65mm Crazybee F4 Lite 1S Brushless Whoop FPV Racing Drone BNF
Optional Version: Frsky Receiver ( Compatible with ACCST D8/D16, Recommend D8 mode)
Flysky Receiver ( Compatible with AFHDS and AFHDS-2A Flysky transmitter)
Drone Wheelbase: 65mm
Weight: 20g
Crazybee F4 LiteFlight Controller
Built-in ESC & Receiver & VTX
Frsky SPI RX version) CRAZYBEE F4 Lite Frsky version Firmware target: CrazybeeF4FR
(Flysky SPI RX version) CRAZYBEE F4 Lite Flysky version Firmware target: CrazybeeF4FS
MCU:STM32F411CEU6 (100MHZ, 512K FLASH)
Sensor: MPU-6000(SPI connection)
Board size: 28.5 * 28.5MM
Power supply: 1S battery input (DC 2.9V-4.35V)
Built-in 5A(each) Blheli_S 4in1 ESC Dshot600 ready
Built-in Betaflight OSD(SPI Control)
Built-in 5.8G VTX
Built-in SPI Frsky/Flysky receiver
Built-in 5V 1A BEC
Built-in voltage detection
Onboard Frsky Receiver Version
SPI BUS receiver Frsky D8 compatible
Compatible Non EU transmitter D8 model
Channels: 8ch
Failsafe support
No ground interference ( Transmitter and receiver 1 m from the ground): 100m~200m
Onboard Flysky Receiver Version
SPI BUS receiver
Protocol: AFHDS and AFHDS-2A Switchable
Channels: 8ch(AFHDS) or 14ch(AFHDS-2A)
No ground interference ( Transmitter and receiver 1 m from the ground): 100~200m
Failsafe support
Onboard 5A BLheli_S 4in1 ESC
MCU upgraded to EFM8BB21
Power supply: 1S LiPo/LiPo HV
Current: 5A continuous peak 6A (3 seconds)
Support BLHeliSuite programmable
Factory firmware: O_H_5_REV16_7.HEX
Default protocol: DSHOT600
SE0802 19000KV / 25000KV Motor
Model: SE0802
KV: 19000KV / 25000KV Motor
Configu-ration:9N12P
Stator Diamter:8mm
Stator Length:2mm
Shaft Diameter:Φ1mm
Motor Dimension(Dia.*Len):Φ10.5mm*14.9mm
Weight(g):1.9g
No.of Cells(Lipo):1S only
Gemfan 1219 3-Blade Propeller Brand Name: Gemfan
Center Thickness:5mm
Prop Disk Diameter:31mm
Center Hole Inner diameter:1.0mm
Quantity: 4 CW & 4 CCW
Weight:0.28g
Onboard 5.8G 40CH 25mW VTX Output power: 25mw
Frequency: 40CH
Input voltage: 3.3V 5.5V
Current consumption: 300mA(type)
Frequency: 5.8GHz 5bands 40 channels
With Race band
Smartaudio ready
Runcam Nano 3 FPV Camera Brand Name: Runcam
Model: Nano 3
Item Name: 1/3 CMOS 800TVL Camera
Electronic Shutter Speed: Auto
Auto Gain Control (AGC): Auto
Min. Illumination: [email protected]
D-WDR: Auto
Day/Night: Color
Power DC 3-5.5V
Current: [email protected] [email protected]
Housing Material: ABS
Net Weight: 1.2g
Dimensions: L14mm*W14mm*H9mm
Lipo Battery ( Included)
Continuous Discharge Rate: 30C
Weight: 8g
Connector: PH2.0
Quantity: 4 PCS
Pacakge Included:
1x Mobula6 1S FPV Racing Drone
4x 1S 300mAh 30C Lipo Battery
1x 1S Lipo/LIHV USB Charger
1x Propeller disassemble Tool
I also ordered some URUAV 3.8V 300mAh 40/80C 1S HV Lipo Batteries 10 pack HERE
Dec 09, 2019, 04:47 PM
Merch's Avatar
Mine just got shipped should be here soon.......first thing is to get rid of the jello from the cam.
Dec 17, 2019, 12:22 PM
Merch's Avatar
If i don't do a review today will post some flight footage up.
Dec 18, 2019, 07:55 AM
Merch's Avatar
A little flight footage added.
Dec 20, 2019, 10:51 PM
Merch's Avatar
Updated with a full review!
Dec 22, 2019, 09:36 PM
Merch's Avatar
Mobula6 VS UR65 0603 19000kv Motors And Snapper6 0603 22000kv Motors (2 min 57 sec)
