Nov 26, 2019, 10:02 AM
Bind Button Broken R-XSR
Anyone know a workaround for a worn down bind button on an RXSR?
Also my Xlite is bound (blue and green light; in SBUS mode) but it’s recognized in BF. Any ideas ?
Nov 26, 2019, 02:00 PM
Not sure why you needed two posts. The bind button is meant to be pressed with your finger not with a sharp tool. It's easy to damage it with a tool.
Dec 05, 2019, 01:39 AM
Circuit complete
Beneath the cellophane and the tactile switch are 2 contacts. I used a tiny piece of wire to complete the circuit. Another time I actually soldered the piece of wire to both contacts then cut the wire once I was in bind mode. Because it's difficult to hold tiny piece of wire and plug a lipo at the same time. When you bound the receiver a receiver # was chosen you should be able to select the correct receiver # on the model setup page. Example I recently pulled a beat up RXSR out retirement. I tried Receiver No. 0,1,2,3 until bingo, it was bound Receiver No. 4. Just from info on these threads and youtube turns out I don't have a single dead receiver. Kewl Beanz...
Discussion R-XSR will not bind jcleek Multirotor Drone Electronics 34 Mar 29, 2021 11:45 PM
Discussion Binding r-xsr akabowman Beginner Multirotor Drones 6 Feb 24, 2020 07:30 PM
Discussion Can't bind r-xsr to my taranis! PLS HELP! tooth pain Beginner Multirotor Drones 1 Jul 04, 2018 05:38 PM
Discussion Horus x10s can't bind to r-xsr Matrix1000 FrSky 1 Mar 27, 2018 11:48 PM
Help! Taranis X9D+ (EU) and FrSky R-XSR binding issues 1Smug_Bastard Multirotor Drone Electronics 5 Jan 18, 2018 02:38 AM
