This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Nov 25, 2019, 06:56 PM
old4570's Avatar
Bee 490 ( wing )
I glued one of the Bee 490 wings together ( just the foam bits )
Really wanted to get some idea on weight ( 34 grams for the foam bits )
And what I was going to do with the wing ?
1s Brushed or 2s Brushed / 1s brushless or 2s brushless
F949 F959 or something else ?
Hmmm , to many choices !
First I need to do more 1s brushless testing ..
Planning things out ( The best laid plans and all that )
34 grams for a base weight ... ?
Motor choice - Do I go for something small and light ? 3 to 4 grams
And then expect thrust in the 40+ gram region ( limited testing so far )
Or go for a heavier motor 10 gram , and maybe get 90+ grams of thrust . ( 1s )
Oh dear , if I go for Uber light , then I will have ? thrust .
But if I go higher , I may have better than 1:1 thrust to weight .
Small motor 4 grams ? Rx 3 grams , ESC 3 grams = 10 grams maybe ?
This would make about 44 grams ..
Then add ? servos and battery and hardware .. Possibly 60 something grams flying weight with 40 something grams of thrust .
The other way , with a 10 gram motor .. It would be only 6 grams more weight for the motor , but a heavier battery needed for CG possibly ..
So maybe 70 something grams with 90+ grams of thrust ..
Interesting .. No?
All up I have 4 wings to put together ..
One wing will be FPV and I did hope to put a flight control board on it .. ( Flight control board ??? - no idea where it is - post ? )
Oh well ! things to mull over ...
Discussion Bee 490mm wing kit ( 2x Wings ) old4570 Flying Wings 6 Nov 29, 2019 08:10 AM
Discussion New FPV Wings by Windrider name Explorer Bee(xBee) Ming FPV Talk 187 Mar 05, 2019 02:12 PM
Discussion Looking for a Predator Bee II wing root and tip trace mdennis Slope 0 May 26, 2016 04:43 PM
Alert Esc 490 or 50hz magrinsi Beginner Multirotor Drones 0 Mar 23, 2016 04:35 PM
Discussion Bee and Ele-Bee, same wing? TropoJet Flying Wings 3 Jan 24, 2007 05:14 AM
