This thread is privately moderated by LeonBlack, who may elect to delete unwanted replies.
Nov 20, 2019, 03:39 AM
RicoCNCSpare
3 important Tips for Cutting Aluminum with your CNC Router
Most people often use the CNC wood routers to cut wood or acrylic. But CNC routers also can cut aluminum. Here are 3 tips to help you.
aluminum bits
1. Use Carbide router bits
Carbide-coated cutters can handle the high RPMs that you need for routing aluminum. Even HSS wonít be able to handle the job. Donít forget to tell you feed and speed calculator that your bit is carbide-coated; it will give you more RPMs.
cnc Aluminum cutting
2. Feed and Speed Rates
Cutting Aluminum is different with wood cutting. This is why you need to calculate your feed and speed rates. The best way to do this is to use and online feed rate calculator.
aluminum router bits
3. Use Fewer Flutes
You may be used to using a four-flute cutter for your woodwork, however when youíre cutting aluminum, a three-flute cutter is your maximum. This will prevent overly large chips which can cause your router to jam. The fewer the flutes, the better. If you have 4 or more flutes, chips jam your flutes, and your bit breaks.
From the above, if you want cut Aluminum, a specialized CNC aluminum router bits are your best choice. We can supply router bit made especially for aluminum cutting. Top quality solid carbide, single flute upcut, specially designed for aluminum or aluminum composite panels milling. For more information, welcome to contact us.
RicoCNC is a one stop shop for CNC spares and tools, if any needs, welcome your inquiry.
Question Router bit suggestions for CNC cutting Garolite XX for foam cutting templates?? Tisr Composites Fabrication 9 Mar 31, 2018 12:41 AM
Help! Looking for someone with a CNC router Wazmo CAD/CAM 4 Mar 16, 2016 07:34 AM
Discussion Cutting RL Adams Readi-board with a CNC Router donektools Foamies (Scratchbuilt) 0 Jun 20, 2013 10:36 PM
Discussion Scaling down plans for CNC laser/router cutting Fossil1977 The Builders Workshop 2 Jun 07, 2009 11:52 PM
