Nov 19, 2019, 07:53 AM
Alert
DJI Mavic Mini FCC mod
1. format sd card with ExFat
2. create *.txt file called ncdo.txt
3. enter into ncdo.txt file:
66 63 63 for 1000mW mode
6d 69 64 for 500mW mode
followed by SHA256 value of your Mavic Mini serial number.
You can use online SHA256 generator to turn your serial number into SHA256 hash: https://timestampgenerator.com/tools/sha256-generator
So for example for 1000mW mode with serial number AC8493299 enter:
66 63 63 f768e57e278014775ad8f20f7a225517529a69a45bbd078028 5a26d84723680a
4. hit save
5. copy the ncdo.txt file to the microSD card
6. make sure Mavic Mini is powered off and insert microSD card
7. power on Mavic Mini
8. Mavic Mini is in high power mode immediately. No need to change any other settings.
Nov 19, 2019, 08:24 AM
Awesome man, it works.
I can not record photos or videos to SD card though, it constantly says "NO SD card".
Nov 19, 2019, 08:29 AM
maybe try to make on card small partition in ExFat, and other partition in normal file system. Maybe this will work?
Nov 19, 2019, 08:34 AM
I will try this with 2 partitions, one exfat for the mod and one fat32 for video.
Nov 19, 2019, 08:35 AM
@gorro report if this work or not
Nov 19, 2019, 08:44 AM
Doesn't work with 2 partition.
It does not recognize the sd card then.
Nov 19, 2019, 08:46 AM
@gorro, so i assume the file not working if sd have only fat32? its working only with exFat?
Also have you tried turning on drone with mod, then pull out exfat card, and then plug in right one with fat32? Is this work?
Nov 19, 2019, 08:56 AM
Can someone also just confirm that this mod is reversible. As in when I stick my normal micro SD card in it'll revert back to its prior mode.
Nov 19, 2019, 09:49 AM
@gorro, is this reversible if u pull out modded sd card?
Nov 19, 2019, 10:05 AM
Yes, removing the SD card will bring back CE.
Nov 19, 2019, 11:33 AM
I was unable to get this to work as I got a SD CARD FILE SYSTEM error when I tried.
Seems that this might not work.
I did ALL steps.
Nov 19, 2019, 12:01 PM
Something very fishy here. @gorro's photo in post #2 is fake. It comes from a video: https://youtu.be/wthfKfXI6ac?t=155 in which 19dBi antennas are used with 2W transceivers to get this range. The setup is explained in another video here: https://youtu.be/ZacSqs2nIW8?t=122
Nov 19, 2019, 12:07 PM
Well it is confirmed that this is 100% FAKE
Shame
Nov 19, 2019, 12:20 PM
So was gorro's account hacked ?
Nov 27, 2019, 03:28 PM
Mavic mini hack
Mavic Mini CE Fcc hack updated guide (1 min 24 sec)
Last edited by Lolik22345; Nov 27, 2019 at 07:00 PM. Reason: Link to youtube was changed
