Nov 19, 2019, 07:28 AM
Help!
no RX input after flashing DYS F4 Pro AIO flight controller
Hi,
I'm trying to upgrade the DYS F4 Pro AIO to a later betaflight version, the actual version is OMNIBUSF4 (OBF4) 3.3.3 May 31 2018.
I'm using a Frsky XSR receiver soldered on UART1, Serial RX port is enabled but there is no more input from the RX after flashing to 3.5 or upper versions.
Nov 19, 2019, 09:04 AM
Did you selected proper serial protocol in config?
Nov 19, 2019, 08:23 PM
Yes, serial setting is right.
With default settings except for serial, motor 3 is spinning when I plug a battery.
Dec 02, 2019, 07:15 PM
Flash AGAIN, sometimes first write doesn't work well. This happened to me 3x on an SPracing F3 card. The 2nd flash cured its ills.
Contest DYS F4+OSD+BEC AiO Flight controller dys123 Multirotor Drone Electronics 1465 Nov 30, 2018 01:39 PM
Discussion DYS F4 PRO V2 AIO flight control dys123 FPV Talk 2 Apr 23, 2018 02:35 AM
Help! Crius MW AIO Pro Tx, Rx flash but no up-dates Flying Canuck Multirotor Drone Electronics 3 Aug 23, 2012 04:38 PM
