Nov 18, 2019, 11:20 PM
Hk swift canard build?
I want a canard to play with; seems interesting.
In my simple head I cut off tail,glue on front.
Turn elevator around and balance to same balance point on wing.
Any reason it won't work?
Whaddya think?
Nov 19, 2019, 12:35 AM
If it flies - I want one!
Petem's Avatar
Partially true, except for the CG bit - moving tail from back to front will move the neutral point of the aircraft, and therefore the required CG, a long way forward.
There are some CG calculators on line that can work it out for you.
Or you can use the Scott Lennon system, and I quote: 'I just threw it off the hill and added weight to the nose till it flew.'
You will also need to make sure you have enough fin up the back to give it sufficient yaw stability.
Low cost fun though - enjoy!
Cheers,
PeteM
Nov 19, 2019, 10:28 AM
It's time for me to fly
JimZinVT's Avatar
I've been thinking about canards too. Like Pete said, there are online CG calculators. One thing I read is you want the canard to stall before the main wing. So the canard angle of incidence should be slightly "leading edge up" (I always forget if that's positive or negative) compared to the wing.
Nov 19, 2019, 11:14 AM
Wow,thank you so much for the info.
This will make the process so much easier and funner.
I appreciate any and all input.
Nov 19, 2019, 12:48 PM
Simple canard from Fly Trap base
This is a quick build canard, using the slope Fly Trap as a starting point. The design was" it looks about right".
The difference was the added power due to local flying sites. It had elevons only. First flight was easy with spot on CG. Performance not at unlike Fly Trap, but maybe more groovy.
Nov 19, 2019, 05:00 PM
That's awesome!
Elevons only.
What else can be dreamt of?
Canard twisty wing!
Nov 19, 2019, 05:28 PM
That is so cool!
Elevons only!
Nov 20, 2019, 10:21 PM
prodjx's Avatar
The rorotillerguy here on rcg will sell you the real deal. Richard Jarel's Telos.
Build Log 1/6th Scale PSS Henschel Hs P.87 (Canard) Scratch Build Owen Hedger Slope 118 May 22, 2019 01:36 PM
Build Log Tron inspired canard type build Timbo383 Foamies (Scratchbuilt) 82 Apr 10, 2018 05:48 AM
Discussion New canard build question ninjasword71 Foamies (Scratchbuilt) 39 Aug 13, 2017 05:31 AM
Discussion 100g very easy to build Canard Delta Gregco10 Foamies (Scratchbuilt) 6 Jun 29, 2016 01:28 PM
Discussion 100g very easy to build Canard Delta Gregco10 Pusher Prop Jet Models 0 Jun 28, 2016 09:13 PM
