Nov 18, 2019, 12:10 PM
1/350 model missouri
I want to convert a 1/350 model missouri to rc I watched a few u tube links where this has been done I just would like to know what they are usine for motors and power packs?
Nov 19, 2019, 02:26 PM
Big Boats Rule!
boater_dave's Avatar
There are a few options here. You could hack a single prop, single rudder to keep the running gear as simple as possible. Next, twin screw, twin rudder. Then, of course, four motors. What kind of operation are you looking for? Just for fun or super scale? At that small scale, twin throttles and the complexity get less noticeable. I hade that in a 1:200 Yamato, but that ship at that scale is not very small.
Using cheap, small, brushed motors you can gang multiple motors on an esc. With brushless, one esc per motor. The 280 size motor is probably most common. Lots available from surplus stores for a few dollars. For an esc, use one from small scale rc mini trucks and crawlers. Amazon will have simple rc car units that take a 6 cell stick pack or 2S lipo. You will only need a couple of amps capability. Rc car esc's do have the annoying reverse/brake lockout, though.
Props can be had several different ways as well. Home made ones are not too hard to make either. Shafts and tubes can be purchased or made yourself. At this small size, simple stuff works, like using silicone fuel tube for flexible shaft connectors.
Check this section for another Missouri build. Lots of good tips and tricks there.
Dave
Nov 19, 2019, 02:44 PM
Just Plane Nutts
AirDOGGe's Avatar
I recommend staying away from coreless brushed motors used today in many drones and aircraft.
Lacking an iron core to absorb heat, coreless motors burn out very quickly and easily under heavy loads, say with a jammed prop for one example. Standard brushed motors like those in Boater-Dave's post are ideal.
More details of the beast: https://www.motioncontroltips.com/wh...ess-dc-motors/
Nov 20, 2019, 01:35 PM
need help
sending this to both of you taht answered my post I am new to this so need help broke my leg so wife got me a1/350 model uss missouri to keep me busy I would like to convert it to rc. 4 motors hobby kink sells a 4 pack of motors mini quad brushed 8.5 by 20 mm would these work and if so can I use 1 esc and 1 lipo battery to run them? thank you rich usn rertired sub service
Nov 20, 2019, 04:51 PM
Big Boats Rule!
Maybe settle on a power setup first, then zero in on motors. Do you have any rc stuff now? Or is this one the one and only? I ask because if you already have batteries and chargers, etc, we can direct you to similar items.
For a super simple 1:350 Missouri, I would think a 6 cell NiMH pack, rc car esc and a cheap 2 stick, 4 channel radio would be just fine. Even a wheel/trigger 2 channel radio, if you prefer, and won't be needing the extra couple of channels. That hull should be able to hold that stuff, along with 2 or 4 motors and shafts.
Dave
Nov 20, 2019, 06:20 PM
Awhile back I got a Spektrum DX5E radio and a B6AC IMAX charger some lipo batterys at garage sale did not know what I was going to do whit them now I know would like all info you can give I think I want to try putting 4 motors in the ship. need to find a place to get 4 and 5 blade props shafts couplings and so forth by the time I get all I need Leg will be well.
Rich
Nov 20, 2019, 07:10 PM
uss missouri
just me boring you at the garage sale the guy said he had a plane but crashed and was not interested in building another he said the radio and charger were good he gave me a motor said it was from plane a receiver a esc a lot of plugs and wire and other stuff he said I could use I guess I'll see.
rich
Nov 22, 2019, 11:47 AM
Big Boats Rule!
The transmitter is fine. I have several of those myself. Did you also get a receiver? Most likely any compatible receiver will work in a 1:350 Missouri. But if you have to purchase one, look for the ones with the longer surface antennas. Not a must have, but they give you more options in some builds.
The charger is also very nice. It will take care of all the batteries you will come across in the hobby.
You just list 'lipos'. How big? How any cells? If they are 2S, about 2500 mah, they should be fine. 3S (11.1 volt) and you may find it harder to get the right motors.
You could go super cheap and just use brass tube and SS rod for shafts. What do the plastic kit props look like? Or check out Harbor Models. They have cast metal props, in 3, 4 and 5 blades (sometimes) in small diameters. Now let's see, the real ship had 17'5", 5 blade props inboard, with 18'3", 4 blade props outboard. In 1:350 scale, that would be 0.60" and 0.63", resp. Harbor Models should have shafts, too. I have used Dumas 1/8" shafts and tubes, but then you need props with a 5-40 thread. Your kit is only 30" long, so you don't need much to make it work.
Motor to shaft couplers, as I mentioned, can be easily made with a chunk of silicone fuel tube. Quiet when running, and easy to make.
Dave
Nov 22, 2019, 04:59 PM
no 2 cells 2 3 cell 11.1 volt will look at harbor models never thought of fuel tube sounds easy. I can buy the right battery just need to know the right motors would those 12 volt mpja motors work sound to good to be true 99 cents each
Nov 23, 2019, 08:29 AM
Translate please.
Nov 23, 2019, 01:57 PM
just saying I had no 2 cell batterys and was looking at some motors from mpja.com
Nov 23, 2019, 03:34 PM
Thank you.
Motors looks OK but the shipping is expensive if that is all you need from them.
Lots on ebay.
Nov 24, 2019, 11:51 AM
Dave looking at some of your threadsa you must have been doing this rc thing aloon time lots of boats you must like sail better. was interested in your small power boats twin screws what brand or type of motors are you usingwhere are you getting them are they reversable and what is that brown piece you have attached to each motor also do you use a esc with the boats?
rich
Nov 24, 2019, 06:14 PM
chris will the 180 2000 to 7000 rpm dc motors worl lots of those on ebay as you said
Nov 25, 2019, 06:15 AM
I am no expert on 180 motors so I cannot advise about whether a particular motor is suitable. I always look for motors with carbon brushes so make sure that is part of the description.
If you are going to use 4 shafts/ props all small dc motors will be happy working in either direction. Your problem is more likely to be finding suitable propellers for both directions of rotation or are you going to make them?
Discussion 1/350 Tamiya Missouri cougar33 Scale Boats 1 Dec 18, 2017 04:16 AM
Discussion USS Missouri 1/120 Scale Rebuild thread klmehaffy Scale Boats 8 Apr 11, 2016 05:30 AM
Help! Mini Hobby Model 1/350 CVN-65 Enterprise English Manual Needed George Jure Scale Boats 8 Feb 27, 2016 04:11 PM
Help! USS Missouri 1/120 Scale Rebuild help! klmehaffy Scale Boats 14 Jan 20, 2016 05:21 AM
