Jan 11, 2020, 01:09 AM
dionnel's Avatar
Hello Victor,
When do you think the files to be available?
Jan 22, 2020, 03:41 AM
eYeboxFPV
victorbah's Avatar
The weather does not allow me to conduct full-fledged tests, but if you are ready to participate in the testing, I can send you a set of stl files and recommendations for printing
740mm wing.
3D Print RC Plane LA5-FN. 740mm (5 min 2 sec)
Jan 22, 2020, 12:07 PM
dionnel's Avatar
740mm wing.
I would like that, Victor. Thanks.
I would do a PLA wing.
Same kind of weather here. We got some 30cm of snow last Saturday night. Time to build!!
Sending you PM with my contact info.
Cheers
L3D
Jan 24, 2020, 10:28 AM
eYeboxFPV
victorbah's Avatar
you can buy files at
https://www.cgtrader.com/3d-print-mo...y/other/la5-fn
Jan 24, 2020, 04:10 PM
dionnel's Avatar
war effort
OK Victor,
I just contributed to your war efforts and likely your first client.
More 1:15 warbirds, please.
L3D
Jan 24, 2020, 10:13 PM
dionnel's Avatar
2 Blades
Hi Victor,
Started to collect the information and to look at the files.
I see a 3 blade spinner. Would it be possible to add a spinner for the more common 2 bladed props?
And if you are short on time, could you otherwise share the CAD file so I can make one?
Thanks!
L3D
Jan 25, 2020, 04:12 AM
eYeboxFPV
victorbah's Avatar
Thank you for your input.
Today I will add a spinner for 2X
Attention! 01/25/2020
added spiner for 2x propeller
Added archive with factory files for S3D
and updated files 15 and 17
Jan 25, 2020, 01:53 PM
Yes !
Thank you for placing the files Victor !
Jan 25, 2020, 11:16 PM
dionnel's Avatar
Yes! Thanks for the new spinner and S3D files!
BTW,
What's the meaning for "matreshka" ?
Seems related to nested Russian Dolls - matryoshka
Part #7 look like a servo tray, is that so?
May I suggest adding a name after each number to pinpoint the purpose or the part?
Printing part #8 now.
Jan 26, 2020, 08:04 AM
eYeboxFPV
victorbah's Avatar
the fuselage and wings are not assembled joint by joint but go into each other by 5mm and abut for alignment. This is similar to how parts of the nesting matreshka are assembled
The glue strip is large and polymer glue can be used. I'm allergic to cyanoacrylate
In the diagram, numbers correspond to file names. These files will be renamed accordingly.
7- platform for elevator servo, I have it installed close to the battery box (see photo)
You can glue or 4 screws.
Jan 26, 2020, 08:09 AM
eYeboxFPV
victorbah's Avatar
I developed a propeller with separate blades. You can do 2x 3x 4x. You can quickly replace a broken blade. Print PETG. If you are interested, files can be obtained for free.
Jan 26, 2020, 10:42 AM
I'm very interested in your propeller design, is it available on Thingiverse or elsewhere yet?
Jan 26, 2020, 11:21 AM
eYeboxFPV
victorbah's Avatar
I added archive files for LA5FN, for my favorite customers for free.
and here
https://cults3d.com/en/3d-model/vari...3d-print-model
And also the archive separately here.
https://cults3d.com/en/3d-model/vari...es-8x6x3-be711
For assembly, you must use 3 screws 1.5x8mm, then put the assembly on the motor shaft and tighten the spiner (using it as a nut)
Jan 26, 2020, 10:21 PM
dionnel's Avatar
Very cool!
Yes, and I see that the spinner is used as the nut.
Should work for a CW or a CCW prop shaft.
And I realize now that you are using a Quadcopter motor - type 2205. (Diagram attached)
This motor is a lot shorter than the one I was planning to use... a BR2208.
Some 15mm shorter.
Your new spinner is not working very well with a collet type prop adapter - hard to tighten.
The Quad motor 2205 is shorter, lighter and will work well with this new spinner, but it is also more expensive.
Jan 26, 2020, 11:17 PM
eYeboxFPV
victorbah's Avatar
part 3 you can print using the Z scale in the slicer to the length you need
I am also ready to make a new part for you 4. Do not forget about the engine tilt. when using cw cww, the slope should be in different directions. item 4 is made for cww. in the slicer you can use the mirror for cw.
News Exceed Formula 1 650MM Electric Powerboat Jim T. Graham Racing Boats - Electric 3 Jan 08, 2016 04:30 PM
Discussion 2 axis gimbal for 210g camera modles FPV Equipment 2 Jul 14, 2015 04:59 AM
Build Log 1/48 Scale La5 Harpye Scratchbuilt Indoor and Micro Models 25 Feb 07, 2008 01:45 PM
RBCkits LA5-FN Construction new2flight Scale Kit/Scratch Built 6 Jul 18, 2004 12:39 PM
