Nov 18, 2019, 06:25 PM
Originally Posted by Zeeb
It's 'gonna tip over sideways because the thing isn't wide enough on the bottom. Also, it'll be susceptible being blown over by wind or some careless person with his turbine.
Fair points, its a short term solution until I find one like the HF version. I'll test it at the house and go from there, like I said all I want it for is to attach the wings the the fuse.
Nov 19, 2019, 10:53 PM
sysiek's Avatar
Hi to all of you guys, I have tried the body shop contraption and I was never happy with,so after some other solutions I found out that the Stanley work horses are the best,the holdup the maximum weight up to 200 lbs per horse they very stable they will work with all jet sizes and they fit every small place + they can be converted to table just provide the plywood top , so just go tho your friendly ACE hardware store and get two sometimes they for $20 for set and buy the narrower one they open better and get some isolation pipe noodle to install on top to protect your jet .
Nov 20, 2019, 01:05 PM
this is the one i use
https://www.napaonline.com/en/p/MSRA1557003
Nov 20, 2019, 03:12 PM
No complaints, very heavy base, wider than it looks. Some heavy round foam over the bars and BVM velcro to hold it in place, it will do what I need it to do for now. Yes, not perfect but it will hold a 17lb jet all day long with no issues. For $30, good quality, sturdy and they used a heavy metal its fine.
As mentioned its only used for either storage or installing or removing wings.
Nov 20, 2019, 03:50 PM
I have a couple of these. They work great on our assembly tables or picnic table.
https://pacificrcjets.com/products/j...6b133682&_ss=r
Nov 22, 2019, 08:55 PM
'By far the best stand for any size plane. Everybody who has seen this bought one as well:
https://hobbyking.com/en_us/hobbykin...del-stand.html
aehaas
Nov 22, 2019, 11:13 PM
Alkaline's Avatar
These are all ... bad ideas long term you will get bowed in fuselages as well as other issues.
Cradle is the only way to go. Good for assembly and the same unit can be used to transport planes. Safe and will not get damaged or get tossed around.
Plus easy to bring where you need to and you can put wings on/off without much fuss.
Nov 26, 2019, 04:23 AM
Alkaline,
I'll remember this thread when I purchase a mini warehouse to store my $100K R/c Jets, $25K trailer and $500 x 5 Cradles lol
Nov 27, 2019, 08:55 PM
Don't know what you guys are talking about but the Harbor Freight stand (which I use) is still available. $20.00 plus tax for 200 lbs support...
https://www.harborfreight.com/200-lb...and-38778.html
Nov 27, 2019, 11:08 PM
rrg
rrg
rrg's Avatar
Originally Posted by C601
Alkaline,
Yep
Nov 28, 2019, 02:49 AM
THAT'S WHY
causeitflys's Avatar
16 bucks with a coupon . I have one in the shop, one in the van and one in the garage. The work horses work well too.
Nov 29, 2019, 10:41 PM
200 Lb. Capacity Portable Work Stand
Item #38778
Discount
-$4.00
(335026530052)
$15.99
Dec 01, 2019, 06:14 PM
gsr
gsr
Harbor Freight-you can adjust it to fit just about anything, cheap, stores easily.
Discussion Where do you purchase LiPos? And which charger do you use? nordemoniac Batteries and Chargers 2 Jan 23, 2018 03:11 AM
Help! Which Sail Servos with an arm (not a winch) do you use in your IOM boats? stevepinder Sailboats 26 Dec 29, 2015 06:43 PM
Discussion Which Turnigy Motor kv do I use? tchanter Power Systems 2 Dec 23, 2015 05:51 PM
Discussion Which Taranis Monitor Mount Do You Use? davidbitton FPV Equipment 3 Nov 10, 2015 05:53 PM
