This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Nov 15, 2019, 08:33 AM
old4570's Avatar
RCX Hobby BE0905 10,000kv on the test stand
The motor only just bolts up to the test stand .
1s tests , I record thrust VIA the stand and RPM VIA the GT power tach .
2s tests are through the stand ...
I started with the smallest prop that would bolt to the motor , my 65mm prop .
1s - 65mm - 24,600 rpm for 42 grams of thrust
2s - 65mm - 36,000+ rpm for 108 grams of thrust ( motor is getting warm , but not so much as to burn ) 6.7A / 51W
The data sheet shows a 3020 prop
1s - 3020 - 19,000+ rpm for 46 grams of thrust
2s - 3020 - I was very gentle in adding power to see if the motor would cook ..
Around 2A the motor was starting to really warm up ...
I got brave and pushed the motor to 5A for only about two seconds and the motor got finger burning hot ...
No I didn't kill the motor , it lives !
But obviously 3020 is just too much for this motor with 2s ... ( I had to try as it's on the data sheet )
I would run that little 65mm prop 2s , or maybe a smaller 3 blade .. ( dont have any right now ) ...
Wow , 108 grams of thrust for a small 0905 ... Even 1s was not horrible ..
Question EDF thrust on test stand vs in the plane djacob7 Scratchbuilt EDFs 27 Dec 27, 2016 02:43 AM
AXI 2208/34: a few test stand results on 2s and on 7v, 8v using PS Dr Kiwi Power Systems 0 Dec 05, 2004 10:14 PM
