Nov 13, 2019, 09:29 PM
Coreless hallbach drone motors
I guess the many poles of a drone motor are useful in reducing the iron (yoke) and lighter and THAT'S why they do it.
but who cares about cogging with a drone they don't glide. with a plane at least it would glide better.
Nov 19, 2019, 03:54 PM
I think I remember the pole being the same diameter as the stator head being ideal. I’m finally modeling hallbach and quasi hallbach arrays today to see what is the ideal ratio of stator tooth head diameter to pole diameter. I’m using a stator with 10mm stator tooth head. With the hallbach it reduces the pole diameter substantially as u need space for sideways magnets.
Stronger smaller poles vs wider n weaker
Nov 21, 2019, 03:09 PM
An itch?. Scratch build.
eflightray's Avatar
I had to do a search to find out what the heck a 'coreless halbach motor' was, weird, (the motor not me )
Google Images search - What is a Coreless halbach motor
I tend to prefer pictures.
Nov 30, 2019, 03:11 PM
Thread I started about hallbach compared w standard NSNS dropped
Been comparing different hallbachs w standard arraignment NSNS magnets using the free motor simulation software Motor Analyst
So far at 30 amps and 3000 rpm with only variable being the different magnet configurations the hallbach kills it on efficiency.
The 50/50 hallbach, w half the poles 5mm and the flux catching sideways magnets 5mm just beats the standard 10mm poles NSNS orientation while increasing the pole size while decreasing sideways magnets ..70/30...80/20... still going but so far 80/20 shows best with 10% better efficiency than the NSNS at the 30amp/3000rpm output
Considering many motors don’t have 100% magnet fill and maybe 75-80%, might be easy to clean out the rotor and glue same magnets back while adding some sideways magnets from off the shelf. There’s so little backiron on all these outrunners so much of the magnetic field is lost and trapping w a hallbach shows to be a big plus. From a 70 to 80% efficient motor with the switch...33.333% better motor.
(Stator is common 12 tooth with 10mm tooth head)
Discussion Hallbach array with 100% magnet fill in rotor Hummina Electric Motor Design and Construction 0 Sep 24, 2016 12:38 AM
Question 6 x 15mm coreless motors pilotjr Multirotor Drone Electronics 24 Apr 15, 2016 09:40 AM
Discussion why no hallbach arrays? how thick is your fluxer? Hummina Electric Motor Design and Construction 11 Aug 04, 2015 03:22 AM
Discussion Hallbach array ring group buy!! Hummina Electric Motor Design and Construction 2 May 08, 2015 02:53 PM
Coreless ESC and non-coreless motor? j8m8l Scratchbuilt Indoor and Micro Models 8 May 21, 2003 08:48 PM
