Morgans Custom 3D Printing Ignition Module
3D printed parts can be easy and useful for model airplanes. I saw this ignition module mount that is available and wanted to share it.
3D Printed Ignition Mount
3D printed parts can be easy and useful for model airplanes. You can design and print your own parts if you have the equipment and skills to do so. If you don't equipment or the skill to design, then companies like Morgans Custom 3D printing can help out. I saw this ignition module mount they are offering and wanted to share it.
The mount is made from a flexible material to dampen vibrations from the engine. It has four recessed mounting holes in the inside for a clean install in your airframe. The cost of the part is $9.99 and you can order it for DLE or DA engines and in a variety of colors. The DA ignition measures 65mmx38mm and the DLE ignition measures 50mmx39mm. If you have different specifications needed, you can contact them about your needs.
Check out the Morgans Custom 3D Printing Ignition Module Here
Apr 19, 2020, 10:33 AM
iflyrc4333's Avatar
does anyone know IF these are still available ? can not seem to get the web links to work ??
Discussion Custom made 3D Printed crawler Cupra313 Rock Crawlers 13 Jan 07, 2019 02:23 PM
Build Log Custom Designed 3D printed Super Decathlon markag 3D Printed Planes 5 Aug 02, 2017 04:25 PM
Discussion Custom ~145mm 3d Printed Tricopter Build EZR0913 Scratchbuilt Multirotor Drones 5 Nov 12, 2016 12:16 PM
Discussion Building a Custom QAV500 X8 & Custom 3d printed Gimbal to carry a Black Magic Camera designandshutter Multirotor Drone Talk 3 Apr 17, 2014 08:23 AM
