Nov 11, 2019, 06:31 PM
Futaba 14 SG Radio
I really need some help programming my 14SG to my full house sailplane. I have basic setup but need to mix evelator with flaps. Can anyone out there help. Thanks. Ken
Nov 11, 2019, 06:54 PM
Dark Side of the Red Merle
Curtis Suter's Avatar
Malcolm Holt
This is for the Futaba 8FG but the radios are nearly identical. I use this guide for my 14SG.
https://www.rcgroups.com/forums/show...mentid=3807207
Curtis
Nov 11, 2019, 08:25 PM
Team Futaba
Silent-AV8R's Avatar
I use a P.Mix with the 5-point curve.
Nov 12, 2019, 09:22 AM
If you want an On/Off or Max/Med/Off operation in a switch try "Trim Mix"
Regards, Joao
Nov 13, 2019, 02:16 AM
Brett
bjaffee's Avatar
Are you looking for elevator compensation when using the flaps, or having the flaps move in response to elevator (aka, snap flaps)?
For snap flaps, you'll use the ELE to CAMBER mix, which allows you to drop or raise both the flaps and ailerons when the elevator is moved.
For elevator compensation when the flaps are moved, there's a bunch of different settings that allow that. As joao says, you can use the Trim Mix, which allows you to set up camber settings of the ailerons and flaps, and the elevator comp on a switch. You can also use the Camber Mix, which allows you to do pretty much the same thing as the Trim Mix, only with a proportional control (for example the slider). And the Butterfly/crow braking mix also allows you to set elevator compensation to go along with it.
Nov 13, 2019, 04:16 PM
https://www.amazon.com/Futaba-14SG-P.../dp/B00BMM9J7A
More than just for sailplanes, but very helpful
-Keith
Nov 13, 2019, 06:33 PM
+1 for the above book
Question Futaba 14 SG lost Range Check function Pinyr Radios 4 May 21, 2019 09:21 PM
Discussion Futaba 14 sg question Twinboom Radios 5 Mar 16, 2018 09:48 AM
Discussion Futaba 14 SG for sale. GeorgiMirov High Performance 19 Dec 20, 2016 06:44 AM
Help! 14 sg futaba radio s-fhss problem soargasm Radios 1 Sep 13, 2013 08:48 AM
