Nov 10, 2019, 04:38 PM
Babaralonius's Avatar
Identify this plane
Would someone be able to identify this plane? It appears to be setup for high start.
Nov 10, 2019, 05:10 PM
whacker's Avatar
have a look at some OLY II pics
Has those lines , though the LE seems rather blunt
whacker
Nov 10, 2019, 05:18 PM
Balsa breaks better
Thermaler's Avatar
Looks like a franken plane. 2M?
Oly 650/Sagitta 600 kinda this, kinda that.
Maybe a little Midway Models Gnome . . . ??
Needs the LE shaped . . . ;>)
Joe
Balsa Breaks Better
Woodies Forever
Nov 10, 2019, 05:20 PM
Too small to be an OlyII
might be an Oly 650
Ed
Nov 10, 2019, 09:08 PM
Thanks guys! Yeah appears to be Oly 650 with a few different building methods
Nov 10, 2019, 10:24 PM
GliderJim's Avatar
Oly 650 doesn't have diagonal ribs. I would say the chord is too narrow as well. Nose looks a bit long too. Not sure what it is.
Nov 10, 2019, 10:26 PM
Kurt Zimmerman ≡LSF 4461≡
kzimmerm's Avatar
My bet is a 2m Gnome. However the leading edge looks quite flat. Also the wing doesn't have the full polyhedral as the 2m Gnome.
https://outerzone.co.uk/plan_details.asp?ID=6872
Can you take a close up of the root of the wing? most importantly the leading edge of the wing.
Thanks.
Kurt
Nov 11, 2019, 01:29 AM
Gots me a good used Hobie Hawk
Steve Corbin's Avatar
I once bought a small Gnome that was hanging in a hobby shop. The leading edges were square and I mentioned it to the guy, and he said that that's what the plans called for. I wanted to fly right away so I bought some plastic tubing and taped it on. It flew very well.
I always wondered how a hobby shop owner could believe that a glider should have a flat leading edge. I figure he flew it and didn't like it so that's why it was only 50 bux with two servos installed. Got a good deal that time, it was well built with the exception of the L.E.'s.
Nov 11, 2019, 03:26 AM
harborflyer's Avatar
Definitely not a Gnome, wrong cut on rudder, wrong wing hold down (dowel front, 1/4 screw at t e, wrong taper on tip, Gnome has taper on on te, not le, more taper and shaped canopy block.
Ross
Nov 11, 2019, 03:28 AM
Balsa breaks better
Thermaler's Avatar
Thanks.
Kurt
I would take that bet if it were a fair one but . . .
Tails wrong, wing tips are wrong and so is the wing attachment.
No balance on a Gnome rudder.
Joe
Balsa Breaks Better
Woodies Forever
Nov 11, 2019, 04:52 PM
Wing span is approximately 70 and fuse is about 39
Nov 11, 2019, 10:12 PM
Looks like a Thermal 73 but the hatch should include the upper portion of the nose and slide on, The tail looks identical so does the wing hold down and bulkheads for the push rods
Nov 12, 2019, 12:58 AM
It's not going to build itself
TRISME's Avatar
Bashed Mini BOT?
Nov 13, 2019, 10:49 PM
I don’t know what it is, but can say with certainty it’s not a Gnome 2M... that is one of the few sailplanes I’ve built, and I see many definite differences. Whatever it is, the builder should have invested in some sand paper for the leading edge :-)
Nov 14, 2019, 06:31 AM
May the Wind Always be Good
Not a Mini BOT and yes Sandpaper would have been Good
Discussion $1.00 Garage Sale find...hoping for help identifying this plane P-51 fan Scale Kit/Scratch Built 16 May 30, 2016 09:50 PM
Discussion Can anyone identify this plane montyb101 Vintage & Old-Timer Designs 6 Sep 29, 2015 04:20 AM
Question Can You Identify This Plane? Rasterize NEAT Fair 2015 10 Sep 26, 2015 08:58 PM
Discussion Can anyone identify this plane hellocopter Vintage & Old-Timer Designs 16 Sep 21, 2015 10:43 PM
Discussion Can anyone identify this plane? hellocopter Electric Plane Talk 5 Sep 18, 2015 08:02 PM
