This thread is privately moderated by bnrusso, who may elect to delete unwanted replies.
Nov 04, 2019, 02:50 PM
lovin' early retired in 2000
bnrusso's Avatar
Mini-HowTo
T16 external balance charge via the battery case.
Trying to do external charging without having charge wires go through back to front of case. Decided to add charge port to the battery case.
1. epoxy socket to case as shown. Sits on SD card side with slotted side up to not interfere.
2. carefully strip wires to solder charge wires without shorting to each other.
3.solder charge wires inside neg first, center to center next and positive last.
4. Protect solder areas with silicone.
Notch case cover to match location.
Now I can use a cheap parallel charger with a double ended extension to charge the battery externally.without unplugging the battery.
Discussion Charging thru the RX? navyguy757 Batteries and Chargers 0 Oct 14, 2018 04:01 PM
Discussion Charger with hot wire foam capability and no external power supply? Implement Batteries and Chargers 8 Feb 20, 2017 06:31 AM
Discussion Spectrum DX6 i - Charging Eneloops Thru Charging Jack? itsme2 Radios 13 Jul 14, 2011 11:45 AM
Discussion How to fish aileron wire thru pre covered wing (no pull string) Txtoby Fuel Plane Talk 24 Aug 23, 2008 01:44 PM
Discussion External Cam Bat thru Power port indtech Aerial Photography 6 Apr 21, 2007 12:07 PM
