Nov 01, 2019, 09:44 PM
Build Log
1/32 Carbon SU-27 Twin 32mm
Well its been over 10.5 years since I started the 1/32 F-16 build and I am going to try it again! I had an impulse buy while traveling and picked up a 1/32 scale SU-27 and decided to give it a whirl. The build will be just like the F-16 and the F-4 but will incorporate a lot of the knowledge that I learned from those jets. The molds will be designed from the start for resin infusion and ease of build with the same overall structure. Here we go!
Nov 01, 2019, 10:04 PM
. This is gonna be good!!!
Nov 03, 2019, 07:30 PM
The fuselage is almost joined. I started working on the parting plane for everything else. Holes had to be drilled for the locating pins and one piece needs a groove to rest in.
Nov 05, 2019, 08:07 AM
Zenoaheli's Avatar
All carbon f15 and 16
Nov 08, 2019, 05:04 PM
Pro Hoarder
turbonut's Avatar
Hey Dan..Great to see you back at it! I was just looking at the F4 thinking it has been too long..Way to many projects getting in the way..Mostly going to work...Cant wait to see how you do on this one
FYI if you ever get the urge you know where your molds are and can barrow them any time
Nov 22, 2019, 04:59 AM
Waaaw!
Dec 13, 2019, 08:46 PM
Getting closer to making molds. So far it has been a lot of filling and sanding getting everything just right. Each engine nacelle will be removable and there will be one more hatch on the front bottom for the radio and battery. The odd shapes are all to fill in holes and to make sure that there are no negatives.
Dec 14, 2019, 09:01 PM
Pro Hoarder
turbonut's Avatar
Nice work. Will you make your own fans for this one?
Latest blog entry: In flight
Dec 15, 2019, 07:42 PM
I will probably start out with off the shelf fans and eventually make custom intake-fan-exhaust ducts.
Dec 16, 2019, 06:10 AM
Subscribed
Dec 16, 2019, 08:23 PM
All of the parts are glued to the plexiglass with caulk and will be trimmed tomorrow.
Dec 17, 2019, 12:05 PM
Pro Hoarder
turbonut's Avatar
I like the idea with the caulking..So simple
Dec 18, 2019, 10:03 PM
Almost ready for PVA and then fiberglass.
Dec 20, 2019, 11:23 AM
Pulled a late nighter and finished one half of the tail mold. I first put on a layer of tooling gel and then backed it up with glass. I always start these layups thinking it will be 2 hours, 6 hours later I finish.
Dec 20, 2019, 12:06 PM
Pro Hoarder
turbonut's Avatar
That is looking great ...Nice to have one mould with most parts on it
Build Log Foamboard SU-27 SU-35 Flanker Dual 55mm carcynic Scratchbuilt EDFs 71 Mar 15, 2018 10:48 AM
Build Log SU-27/SU-30 XXL Twin Pusher or Twin EDF Wobisch Pusher Prop Jet Models 24 Jan 09, 2015 03:34 AM
finally maidened my 32" su-27, a fair success... submarco Pusher Prop Jet Models 6 Nov 24, 2005 01:37 AM
Skyzone SU-27 twin EDF? sguty Electric Ducted Fan Jet Talk 20 Oct 06, 2005 06:28 AM
Yippee! Su-27 twin EDF and Mig-29 Twin EDF kit release imminent if enough interest? mjblack Electric Ducted Fan Jet Talk 159 Jun 18, 2004 01:29 AM
