This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Nov 01, 2019, 09:15 PM
old4570's Avatar
Budget 2204 2300kv test
Tested on the Turnigy V3 test stand
2s
7045 2 blade = 12.3A / 470 grams of thrust / 10,800 rpm
6045 2 blade = 8.2A / 384 grams of thrust / 13,400 rpm
5051 3 blade = 8.57A / 295 grams of thrust / 13,190 rpm
3s
5051 3 blade = 13.66A / 500 grams of thrust / 17,100 rpm
5042 3 blade = 10A / 434 grams of thrust / 19,800 rpm
6045 2 blade = 13.2A / 653 grams of thrust / 17,400 rpm
I don't have a 6x3 or 5x3 that will fit this motor .. So I had to use props on hand that fit .
I did see over 150 watts with the 3s battery , the motor just got a little warm . So at around 150W looks like we are starting to load up the motor . How much more it will take before it cooks ? I would say that on paper the motor is under rated quite a bit . Personally I would be happy to run this motor to 150W for short bursts , like take off or a speed pass .
I have two wing kits , one is 800mm . ANd I have seen a lot of people put 2204's in that 800mm wing . If it can be built to 150 grams or less ? Then we might be looking at a thrust to weight ration of 4.3 to 1 or better ? on 3s . ( Thats crazy ) or 3:1 on 2s ....
Motor Link @ banggood
Nov 02, 2019, 09:44 PM
Waste Nothing
RickC_RCAV8R's Avatar
Been flying these on a couple of 250mm quadcopters for over a year now and LOVE 'em ! Twisting Dalprop 6 X 3s with authority . 5 X 4s are awesome for very quick manouvers . ALL on 4S power . No worries for these guys as they WILL handle the flight abuse . At $4.99 US apiece on HK ; a bargain .
Mini-Review Thrust test new Storm 2206-2200kv, 2208-2200KV and 2204-2300KV motors Therotak Mini Multirotor Drones 13 May 22, 2016 12:10 AM
Discussion Cobra 2204 2300kv thrust tests with xrotor 20a Blheli 14.1 discophil Multirotor Drone Power Systems 6 Sep 23, 2015 03:09 PM
Discussion Cobra 2204 2300Kv or Cobra 2204 1960Kv HarryFPV Multirotor Drone Electronics 7 Aug 11, 2015 11:14 AM
Data Thrust Test: Airbot Titan 2204 2300KV and Cobra CM2204 2300KV foobarbazqux Multirotor Drone Power Systems 22 Jul 09, 2015 04:26 PM
